Zum Hauptinhalt wechseln
Was du brauchst
Einführungsvideo
Dieser Teardown ist keine Reparaturanleitung. Um dein iPhone 5c zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. iPhone 5c Teardown, iPhone 5c Teardown: Schritt 1, Bild 1 von 1
    • It's a big day, today. We just finished the iPhone 5s teardown, and now it's time to move on to the iPhone 5c.
    • This is the second teardown of today's tear-a-thon, and though this device may be feeling blue, Teardown Team morale is higher than ever! Nothing can bring us down on such a beautiful night—if only the same could be said for these guys.
    • We've said it before, but we really want you, our adoring public, to know how grateful we are for our good friends at MacFixit Australia for letting us use their office in Melbourne for the second teardown. Remember, they stock Mac and iPhone upgrades/accessories.
    I have a IPhone 5c pink and I just noticed realised the screens coming off
    Blandhy - Antwort
    Hey Blandhy, it is possible that your battery is swelling up, pushing the screen away from the frame. This phone is fairly easy to open, so I suggest taking a look at the battery guide to lift the display and see if the battery looks more inflated than the one in the guide photos. Best of luck!
    Sam Goldheart -
  2. iPhone 5c Teardown: Schritt 2, Bild 1 von 2 iPhone 5c Teardown: Schritt 2, Bild 2 von 2
    • With an array of colors to choose from (White, Blue, Pink, Green, and Yellow), we decided upon blue.
    • What makes the iPhone 5c different from the iPhone 5s? We're bent on finding out. For starters, the rear case is composed of plastic—looks like our work here is done…
    • Technical Specs include:
    • Apple A6 system on a chip (SoC)
    • 4-inch Retina display with 326 ppi
    • 8 megapixel iSight camera
    • 4G LTE connectivity
    • 16 or 32 GB Storage
    "What makes the iPhone 5c different from the iPhone 5s?"
    iPhone 5 owners are actually more interested in the differences between 5c & discontinued 5.
    Benjamin D - Antwort
    from what i can see its only the colorful cases is what is different from the 5 and 5C
    _Z_ -
  3. iPhone 5c Teardown: Schritt 3, Bild 1 von 3 iPhone 5c Teardown: Schritt 3, Bild 2 von 3 iPhone 5c Teardown: Schritt 3, Bild 3 von 3
    • So what does the "c" really stand for? We've already identified a major difference in "color," but we aren't ready to close the book on this mystery, just yet!
    • As promised, every port, button, and slider has had its metal swapped out for plastic.
    • "Cheaper," per chance?
    • Not only are these parts made of plastic, they also look a lot more…"childish."
    • The volume buttons are considerably larger, and the 10-hole microphone grille and 16-hole speaker grille have been replaced with 1- and 4-hole grilles, respectively.
    Why use the word childish? The iPhone 5 was the first non-plastic shell iPhone wasn't it? Was the iPhone 4 considered childish? Are all the plastic Android-based phones childish? Well, forget the last comment because everyone knows the answer.
    plink53 - Antwort
    I know what "c" is for! And that's good enough for me.
    Edis0n - Antwort
    The original iPhone model had an aluminum case. The 3 and 3gs were plastic. The 4's went to a glass and aluminum frame. The 5 appears to me to be more steel than aluminum. The problem I saw with the 5 is a lack of seals like the 3's which meant oxidation will form around the edges (corrosion).
    ozarkana - Antwort
  4. iPhone 5c Teardown: Schritt 4, Bild 1 von 2 iPhone 5c Teardown: Schritt 4, Bild 2 von 2
    • These super tiny Pentalobe screws are slightly different than the ones we found in the iPhone 5 and 5s.
    • Here's how the Pentalobe screws compare in size to an Australian coin of undetermined value.
    • ¡ʍouʞ oʇ ǝʌol plnoʍ ǝʍ 'sı uoıʇɐuıɯouǝp ǝɥʇ ʇɐɥʍ ʍouʞ ɹǝpun-uʍop spuǝıɹɟ ɹno ɟo ʎuɐ ɟı pu∀
    • EDIT: it's a 50 cent coin roughly an inch in diameter for the yanks.
    50 cent coin is the denomination
    heathsouter - Antwort
    The whole "durable shell" is not really true, after checking out some Test drop videos you can really see the its much worse then the aluminium in the iPhone 5S http://www.amongtech.com/first-iphone-5s...
    John Mark - Antwort
    17 year old fandroid performing the tests.
    plink53 -
    Just a small note here, the 50 cent coin in Australia is much larger than the 50 pence coin in the UK. So the photo can be misleading if you've had no experience with Australian currency. (Their notes have transparent plastic parts in them! :O )
    Oliver - Antwort
  5. iPhone 5c Teardown: Schritt 5, Bild 1 von 2 iPhone 5c Teardown: Schritt 5, Bild 2 von 2
    • The front panel assembly is dispatched using a small suction cup. Despite the plastic backing, the display assembly of the 5c fits just as snug as the 5s and 5.
    • We are beginning to wonder if the "c" stands for "copycat".
    • Though it may look like we are performing painful dental procedures on a Smurf, we assure you that removing the 5c screws is as quick and painless as Novocain.
    So do i not need a pry tool to take the screen off? Just the suction cup?
    Faryn - Antwort
  6. iPhone 5c Teardown: Schritt 6, Bild 1 von 3 iPhone 5c Teardown: Schritt 6, Bild 2 von 3 iPhone 5c Teardown: Schritt 6, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    iOpener
    $19.99
    Kaufen
    • Removing the battery requires the assistance of our iOpener, a departure from the easy battery replacements of yester-year.
    • After a few minutes of heat and some diligent spudgering, we leave our iPhone 5c black and blue in a pile of pieces.
    • Too bad we didn't know in advance about these fancy new strips of stretch-release adhesive, or we'd have had a much easier time.
    I think those are not adhesive strips but thermal tapes.
    Prateek Garag - Antwort
  7. iPhone 5c Teardown: Schritt 7, Bild 1 von 2 iPhone 5c Teardown: Schritt 7, Bild 2 von 2
    • Checkpoint reached—battery released!
    • Though the 5c is essentially a repackaged iPhone 5 (in colored plastic, in case that hadn't been made apparent, yet), the battery has been beefed up a bit, clocking in at 3.8 V—5.73 Wh—1510 mAh, compared to the 3.8 V—5.45 Wh—1440 mAh battery of the iPhone 5.
    • Hopefully, this will address some issues with battery life brought about by the iOS 7 update.
    • Larger battery…Hmmm, could the "c" stand for battery "capacity?" It's a theory; it's probably wrong.
  8. iPhone 5c Teardown: Schritt 8, Bild 1 von 3 iPhone 5c Teardown: Schritt 8, Bild 2 von 3 iPhone 5c Teardown: Schritt 8, Bild 3 von 3
    Spudger
    $3.99
    Kaufen
    • As we go to remove the antenna connectors with our trusty spudger, we notice something we haven't seen in any recent iPhone: adhered connectors.
    • In case our years of teardown tirades were too subtle, we'll reiterate: we strongly dislike glue.
    • On a scale from 1 to taking selfies with an iPad, strongly adhered devices rank right up there with proprietary screws and people who don't appreciate cheesy puns.
    • Annoying adhesive aside, we get to removing the logic board from our little blue iFriend.
    I guess the 4S isnt considered a recent iPhone even though its still being sold.
    Computech - Antwort
    I'd much rather have the insides of my phone secured to the point where they don't fall apart in normal use. I believe that is why Apple is using glue. They don't want people coming in with phones with tiny connectors that fell apart when a little bit of glue would have kept them in place forever. I know iFixit stresses repairability but I'd rather have a device that doesn't require repairs every five minutes.
    plink53 - Antwort
    The connector next to the battery connector in my case does not clip to the board, is this connected only by the pression and the glue?
    tegolategola - Antwort
  9. iPhone 5c Teardown: Schritt 9, Bild 1 von 2 iPhone 5c Teardown: Schritt 9, Bild 2 von 2
    • Front side of the logic board:
    • Apple A6 APL0598 application processor
    • Qualcomm MDM9615M LTE Modem
    • Qualcomm WTR1605L LTE/HSPA+/CDMA2K/TDSCDMA/EDGE/GPS transceiver.
    • While it's not as flashy as its newer counterpart, we have to admit a certain fondness for the A6.
    • The iPhone 5c contains Elpida B8164B3PM-1D-F 8 Gb (1 GB) DDR2 RAM under the A6 system-on-a-chip.
    Again, as I commented on 5s...I am very curious about the LTE & cell chipset(s)...4 different ones, seem to be shared between 5c & 5s http://www.apple.com/iphone/LTE/ ...I am wanting to know how Apple has dealt with this...is the cell section modular/interchangeable or just different chips soldered in the same slots on the logic board?
    They have a lot more iPhones to deal with than before: 5c=2 Mem sizes (only 1 on middle level iPhone in past), 5 colors, 4 LTE variations...5s=3 Mem sizes, 3 colors, 4 LTE variations. Whereas the non-LTE 4S has one cell chipset, 1 global model, 2 colors (1 mem size).
    So are they using a sub-logic board that is interchangeable for 5c or 5s? How is this changed from iPhone 5 (iPhone 5 could not do LTE in emerging markets, such as china, which is why it was discontinued, they had to have 2 LTE iPhones for these new markets, so, that is one of the main reasons for 5c and kill 5, also=biggest change from 5>5c).
    What is the same about 5c & 5s? How Logic board is attached?
    For iphone 5 they use the same PCB with different chips, for iPhone 5c/5s they use two different PCBs for US/world versions that are very different.
    Tom Chai -
    Just different chips soldered in the same place on the board. The circuitry is the same for each chip allowing Apple to the same board just different chip.
    Alec - Antwort
  10. iPhone 5c Teardown: Schritt 10, Bild 1 von 1
    • The back of the logic board:
    • Toshiba THGBX2G7B2JLA01 128 Gb (16 GB) NAND flash
    • Apple 338S1164
    • Apple 338S1116 Cirrus Audio Codec
    • Qualcomm PM8018 RF power management IC
    • Broadcom BCM5976 touchscreen controller
    • Murata 339S0209 (based on the Broadcom BCM4334) Wi-Fi module.
    Whose gyro and accelerometer is built in? Thank you
    Mark - Antwort
  11. iPhone 5c Teardown: Schritt 11, Bild 1 von 1
    • Backside of the logic board continued:
    • Skyworks 77810-12
    • Skyworks 773550-10
    • Avago A790720
    • TriQuint TQM6M6224
    • Avago A7900
  12. iPhone 5c Teardown: Schritt 12, Bild 1 von 3 iPhone 5c Teardown: Schritt 12, Bild 2 von 3 iPhone 5c Teardown: Schritt 12, Bild 3 von 3
    • Since we have both of the new iPhones on the table, we'll take a little comparison tour:
    • Interestingly enough, the 5s (on the right) sports a slightly lighter display assembly, despite the addition of a fingerprint sensor and luxurious sapphire home button.
    • The 5c's 1510 mAh battery is just a hair slimmer than the 1560 mAh battery of the 5s.
    • We've been wondering if there's any chance of cross-compatibility of display assemblies between the 5c and 5s.
    • Alas, the FaceTime/speaker connectors are different sizes, killing hope of that plan.
    • We are sorry to crush any hopes and dreams, but in the mean time, our Googling has revealed the answer to a question that has been haunting us for weeks.
    So you mentioned that the 5s and 5c screen assemblies are incompatible, but my question is can i put an iPhone 5 screen (i.e. a white one) onto a 5c?
    Ben Stone - Antwort
    The iPhone 5C and 5S LCD and Digitizer Assemblies have to be the same. They might have different prox flex's (camera, prox, speaker) but they are both compatible.
    Alec - Antwort
    No. You would need an iPhone 5S screen assembly.. The connections are in a different place and are different making it so you can not use an iPhone 5 screen on an iPhone 5S/C
    Alec - Antwort
    Could you put the 5s screen/TouchID sensor onto a 5c body? And perhaps have the 5c run the TouchID?
    That's what I'd really want.
    Philip Snowden - Antwort
  13. iPhone 5c Teardown: Schritt 13, Bild 1 von 2 iPhone 5c Teardown: Schritt 13, Bild 2 von 2
    • Flip you for it! Tails or rear-facing camera?
    • Comparing the cameras on the iPhone 5c (left) and 5s (right), we see little difference between the two. The one difference between the 8 MP rear-facing cameras is the aperture. The 5c boasts an aperture of f/2.4 compared to the f/2.2 of the 5s.
    • Additionally, the vibrator motor assembly in the 5c is actually slightly larger than that of the 5s, despite its similar component design.
    f/2.2 is actually better.
    Jason Murray - Antwort
  14. iPhone 5c Teardown: Schritt 14, Bild 1 von 2 iPhone 5c Teardown: Schritt 14, Bild 2 von 2
    • You've seen the internals, but a new question remains…Will it bend?
    • We may not have super strength, but we put this case to the muscle test, anyway. The results: this lacquered plastic is as strong and blue as Captain Planet.
    • It's good to know that, though the rear panel is made with plastic to presumably cut costs, Apple did not compromise build quality in the process.
    • Next we rip out the 5c's still-beating heart ports.
    • Much like internal organs, these ports are connected, so there is no easy way to get at just one of them.
    • Continuing this analogy, our ideal person, much like our ideal device, would be modular like this (work safe, we promise).
    I wonder if the case is made out of plastic because it can be manufactured easier than the aluminum case. The video showing the injection molding, CNC detailing and drilling (aluminum can handle a much smaller hold than plastic since it doesn't melt at a low temperature), and robots "gluing" and placing the (probably stamped) steel antenna frames should be less expensive and faster to do than milling an aluminum block and finishing it. This process can be done in any country. I'd like to see how the individual components are added. It would be really fantastic if Apple were able to construct a robot and parts that could be totally put together my machine instead of requiring tiny hands to place tiny components and insert even tinier screws.
    plink53 - Antwort
    So with the connections being different on the logic board for the display, would it be physical possible to swap the innards of the 5s into the 5c?
    beerad - Antwort
    At the end of this teardown they did a side by side comparison of the 5c and 5s back housing designs and they seem to be interchangeable as they appear to have the screw holes in the same format on both 5c and 5s rear casing. I could be reading it wrong but the teardown says it will do a side by side comparison of the 5c and 5s back housing and only the only difference mentioned is the plastic vs metal.
    jeremylester56 -
  15. iPhone 5c Teardown: Schritt 15, Bild 1 von 2 iPhone 5c Teardown: Schritt 15, Bild 2 von 2
    • All we're left with is a serious case of the blues.
    • Standing next to its sibling, iPhone 5s, the colorful 5c case looks very similar in structure.
    • The most noticeable difference is (unsurprisingly) the material.
    • The less visibly noticeable difference is weight: A greater mass of plastic is required to match the strength and durability of a lesser mass of aluminum. The 5c rear case is way heavier: 43.8 g vs 25.9 g for the 5s.
    • Nestled within the polycarbonate backing, is a steel frame that serves as an antenna and structural support.
    • As we approach the end of our teardown, we think we have solved the mystery of iPhone naming convention: and here it is.
  16. iPhone 5c Teardown: Schritt 16, Bild 1 von 2 iPhone 5c Teardown: Schritt 16, Bild 2 von 2
    • iPhone 5c Repairability: 6 out of 10 (10 is easiest to repair)
    • Just like in the iPhone 5, the display assembly is the first component out of the phone, simplifying screen replacements.
    • The battery is still fairly easy to access, even though it's not technically "user replaceable."
    • Adhesive on the antenna connectors hinder disassembly.
    • The battery has lost the 5's convenient pull tab, and gained more resilient adhesive—it now requires heat and prying to remove.
    • The iPhone 5c still uses Pentalobe screws on the exterior, making the 5c difficult to open.
    • The front glass, digitizer, and LCD are all one component, thereby increasing cost of repair.
    The one score down is totally unfair. Apple chose the command tapes for easy removal, and you guys took one score off just because you didn't know how to use them. This device should get at least 8, very modular design and straightforward repairs. The only frustration is the fused display
    Tom Chai - Antwort
44 Kommentare
Dear iFixit team,
is there any way you could find out, if the iPhone5S's camera could be used in an "old" iPhone5?
I would immediately order one from you, as soon as you had it in stock! :)
Thank you for your time...
eeegor87 - Antwort
No unfortunately you can not.. The camera is different. The iPhone 5S has the connection for the camera on the top of the board, and the iPhone 5 has it on the bottom of the board. So the camera connection is on the under side of the 5S and the 5 has it on the top. Also the 5 has the flash connected to it. The 5S does not.
Alec - Antwort
Can iphone 5c camera be replaced with iphone 5s camera? Because the assembly is remarkably similar.
Sondre Lerche - Antwort
Check Here... iPhone 5C Screen Replacement https://www.youtube.com/watch?v=0DVHDBnU...
Gadget Guru - Antwort
A friend spilled some Sangria on his iPhone 5c, and now the earpiece speaker doesn't work. I recommended swabbing it with a Q Tip and a sparse amount of Windex, but if that doesn't work I'm looking at replacing the earpiece. I do have a question on this though... could the spill have messed up the proximity sensor or the controlling chip for it? He is under warranty but I don't think Apple will replace it because it was a spill.
ozarkana - Antwort
Would the iphone 5 logic board be compatible with the iphone 5c?
Dwayne Jones - Antwort
Is it possible to fit the higher capacity battery from a 5S into a 5?
Martyn - Antwort
My iPhone 5c battery cover is looking a bit past it and I'm thinking of changing it. Could I buy a iphone 5 cover and use that?
mick gilzean - Antwort
Can someone please tell me how long it takes to disassemble this phone? (see step 16)
Jackieee - Antwort
5-6min depending on the route you take to getting the screen off.
Brandon Ranson -
Hi team plz help I broke my iPhone 5 c replaced the screen twice but touchscreen won't respond and now says my phone isn't connected to Internet much app .
Angela Mcpherson - Antwort
Have you tried replacing the screen?
Sam Murphy -
Is it possible to replace the A6 processor with the A8?
jesse slaughter - Antwort
Can I replace the A6 processor with the A8?
my screen wont turn on since i dropped it and when i charge it it heats ups alot....help
Joe Gatewood - Antwort
i dropped my 5c and the screen wont turn on, when i charge it, it gets super hot....help
Can I put a iPhone SE into a 5C case? I love the look of pink 5c, but want so much it works like a SE, with powerful A9 and 12mp Cam
Dax Liu - Antwort
I don’t see why you couldn’t except the internals are designed to fit the case. You might have to design your own case that looks like the 5c, shave down some internal structures, or do something like that. Good luck, though!
Liam Powell -
Can I put an iPhone SE into a 5c case? Love the pink 5c so much, but so much wanted it works like a SE with powerful A9 and 12-mp camera.
Dax Liu - Antwort
5c no loner responds to touch screen/can not slide screen to unlock device. Possible problem?
krissykuku4 - Antwort
Same i tried hard resetting its still not working might be chip inside screen
Chason Banks -
5c no longer responds to touch screen. Cannot slide in order to unlock phone
iphone 5c ini tidak bagus
saya pemakain ga sampe 1 bulan sudah rusak
garansinya jga tidak ada gunanya di buat
terus kerusakan yang seperti apa yang bisa di pake untuk garansinya
mengecewakan sekali
Mark Nainggolan - Antwort
my iphone5c isnt unlocking they say its the the chip a6 something like that that control the sllide unlocking
Chason Banks - Antwort
Can I put an SE logic board in a 5c? Or can I carve the 5c into a 5/5s/SE shape?
Justin B. (Nytalite) - Antwort
My 5c Blacked Out & ' The Phone Store Says There Are Pieces Missing ' In My Phone & ' Tht I Need S New Screen But A Different Phone Store Is Sayin ' My Phone Is Damaged & ' Not Fixable . Can Pieces Be Inserted To Help My Phone Come Bck ' On !?
Tameia Sims - Antwort
is it possible to put 5c logic board in 5s case with all 5s component?
Muhammad Nasrul - Antwort
It is possible to replace the chip Qualcomm MDM9615m Iphone 5c.
venanciosouza3 - Antwort
My daughter's 5c says it's "searching" for a network. The store says it has to be replaced. Is there anyway to install a new antenna?
Niki Ailshie - Antwort
the adhesive for the battery has pull tabs at the bottom of the battery
devincrapse - Antwort
Phone store told me the brain is dead on my sons 5c would that be classed as the logic board
danyelle wright - Antwort
Do you know what part of the iPhone 5c that saves the photos/videos? Because my iPhone 5c recently got stuck on the apple logo reboot and won't go out of it and when I try plugging it into my computer, it won't recognize it. So I was thinking if I took that part out of the iPhone and put it in a different one, would all my photos/videos be on my new iPhone, probably an iPhone 5 for now. Or is something else perhaps broken in my iPhone 5c that can be replaced to make it work again.
simonsz1 - Antwort
Hi my iPhone 5s is I cloud is locked so I was wondering if I cuold put my iPhone 5c internals into it
Kerry - Antwort
I'm hoping someone can answer this, I'm not finding anywhere where the GPS is located on the iPhone 5c. I've found it several places for the standard 5 and I see above where the chip is located but what about the antenna? Is it part of the wifi/bluetooth array? I'm looking for the easiest hardware/physical method to disable the GPS on the iPhone 5c. Not in software but by removing the hardware. Thanks
Eddie - Antwort
Is it possible to replace the "guts" of a 5c with the "guts" of an SE? I really like my 5c, especially the casing. But would I be able to buy an Iphone SE with say a broken screen, and take all the internals and put them inside an Iphone 5c frame? Size wise it looks like it might be possible.
ahigbee - Antwort
Hi team I want to ask, is It possible if I want to swap housing between Iphone 5C and 5S? Thank You
aditya.arifbudiutama - Antwort
Is there a way to remove the gps unit, or unpower it, that doesn't mess the rest of this phone up? I don't mind losing wifi and bluetooth in the process. When I unplugged the wire underneath the mobo on the top by the camera, I believe that is the gps/wifi/bluetooth unit, the phone started getting hot and losing regular signal as well and then eventually the bottom button wouldn't work. Thoughts?
Eddie - Antwort
Can change the iphone 5c body to 5s body? U said, it is similar structure,
So it can?
Moe Thar - Antwort
Dear iFixIt,
Is there a way to change out the internal memory [16GB] to a higher capacity [EX. 64GB] in an iPhone 5C, while still maintaining all previous information on the old card?
If it is at all possible, what is the process and where can I find the materials I need in order to do it?
Jess Me - Antwort
it is posibble to replace iPhone 5c Rear Camera Lens Cover. why it so hard to find the lens cover. help me my lens cover had scratch so much
uruki yuuhi - Antwort
Dear , iFixlt — I have a white 5c and it has battery issues ….the battery just works upto 4 hours on standby and it the meantime releases a lot a heat…..what could be the problem and please tell me is it repairable? ?
Anshumaan Kumar - Antwort
Is it possible to replace the iPhone 5c’s home button with that of an iPhone 5s, and is it possible to replace the iPhone 5c’s vibrator with that of an iPhone 4 Verizon? If so, how?
Thomas Zinno - Antwort
Can i use the frame of the i phone 5s on the i phone 5c it kinda looks desame
Lance Orven - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 34
Letzte 30 Tage: 209
Insgesamt: 371,303
