Einleitung
This teardown will show step by step a disassembly of the Apple iPhone dock. Hope you enjoy!
Was du brauchst
Carefully remove the clips on the side by pushing up with the Jimmy. If needed, use the plastic Opening Picks to keep the back piece from popping back into place.
The silver adhesive is covering two Phillips screws at opposite ends of the dock. Peel back the adhesive on these areas and remove both screws.
Remove the back plate once the screws are out.
Remove four Phillips #000 screws surrounding the Lightning connector.
A similar adhesive can be found covering the plug for the Lightning connector. Peel the adhesive back and gently lift the cable to disconnect the connector.
Ein Kommentar
is it possible to find the lighting connector, since I have one that fell and it got all twisted and damaged and it tore the connector
