Einleitung
So basically I am tearing down the whole phone from step to step. Please just follow the directions of my tear down the I Pod Touch 5th generation
Was du brauchst
Have an I pod dosen't matter what color it is
You would also need something sharp for the screen or a blow dryer to remove it
Before removing the screen you need to appply heat to the I pod so that the pod can be easy to lift up.
Be sure to use a spudgre so you can lift the phone up
After taking of the screen use 3.5 millimeter size screw driver to take off the digitizer.
Do not add pressure when screwing off.
After a short while remove the digitizer slowly off so that you can only see the battery.
Please do not press on the battery,cause the battery is lithium
When replacing the battery use the spudger so to pull the battery up
And after using the spudger use a blow dryer and turn it on low so that that battery can lift up
