Zum Hauptinhalt wechseln
Speziell für diesen Teardown benötigte Werkzeuge
Dieser Teardown ist keine Reparaturanleitung. Um dein toshiba satellite pro T130-138 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. turn off your computer for safety reasons
    • turn off your computer for safety reasons
  2. flip the computer over and remove the 12 philips 0 screws this will make the keyboard and trackpad part free then unscrew the two philips 0 screws guarding the 2 RAM boards then unscrew the two philips 0 screws guarding the 2 RAM boards
    • flip the computer over and remove the 12 philips 0 screws this will make the keyboard and trackpad part free
    • then unscrew the two philips 0 screws guarding the 2 RAM boards
  3. you can remove the 2 RAM boards by lifting them up here we have two beautiful RAM boards
    • you can remove the 2 RAM boards by lifting them up
    • here we have two beautiful RAM boards
  4. by unscrewing these 2 star screws size 6 we can lift the hard disk plate. the hard disk is secured by two philips 0 screws the hard disk is secured by two philips 0 screws
    • by unscrewing these 2 star screws size 6 we can lift the hard disk plate.
    • the hard disk is secured by two philips 0 screws
  5. unscrew the hard disk screws and use the spudger to slide the hard disk out pull it up and put it aside
    • unscrew the hard disk screws
    • and use the spudger to slide the hard disk out
    • pull it up and put it aside
  6. slide the two plastic pieces holding the battery and pull it out you will have to take all these silver philips 0 screws
    • slide the two plastic pieces holding the battery
    • and pull it out
    • you will have to take all these silver philips 0 screws
    • but for the next step remove the ones I am pointing
  7. Android Fix Kits
    A new screen or battery is one kit away.
    Jetzt kaufen
    Android Fix Kits
    Jetzt kaufen
  8. use a spudger to remove the bezel
    • use a spudger to remove the bezel
  9. remove the 2 philips 0 screws and get the keyboard out with a spudger lift the black plastic and pull the cable out
    • remove the 2 philips 0 screws and get the keyboard out with a spudger
    • lift the black plastic and pull the cable out
  10. follow the same process to disconnect the trackpad, button and lights. you will end up with something like this you will end up with something like this
    • follow the same process to disconnect the trackpad, button and lights.
    • you will end up with something like this
  11. you have to take this screw located on the RAM boards connector use a spudger to lift the top off, go all around the laptop and you'll get it off It looks really beautiful!
    • you have to take this screw located on the RAM boards connector
    • use a spudger to lift the top off, go all around the laptop and you'll get it off
    • It looks really beautiful!
  12. this is not a step I am not going deeper into this so I don't break anything you can go if you want.
    • this is not a step I am not going deeper into this so I don't break anything you can go if you want.
    • anything that you do that is not shown in the teardown is at your own risk
  13. the inside contains
    • the inside contains
    • two speakers
    • one cooler
    • ports
    • screen connector
    • and a giant interesting motherboard
    • oh and don't forget about the memory card reader
  14. here we disconnect the battery slot and we get the card reader connector out such as the screen
    • here we disconnect the battery slot
    • and we get the card reader connector out
    • such as the screen
  15. remove the rest of the cables some of the cables are glued to the mother board don't remove them
    • remove the rest of the cables
    • some of the cables are glued to the mother board don't remove them
    • remove the mother board screws
    • the screen connector is secured by 2 philips 0 screws
  16. if you did what I did you will end up like this
    • if you did what I did you will end up like this
    • I don't want to go deeper because I don't want to take the risk of breaking or damaging the computer
    • if you go deeper it's at your own risk
    • I will give it an 8/10
    • after removing the screws everything is easy to remove
    • the top, bezels and keyboard come easy off
    • some of the cables and components are fragile with makes it harder to remove
    • the track pad is covered with a sticky plastic with makes it harder to tear down
    • any components that are not well connected can make the computer not function well.
    • the opening tools are there if you want to disconnect some cables that are hard to disconnect
storm builder
371 Reputation
1 Anleitung geschrieben
you should take the battery out first, you might shock yourself
Luke - Antwort
So you took the HDD out before the battery… but you turned off the computer for safety reasons.
Isaac Sastre - Antwort
for everyone that was thinking I started the teardown with out removing the battery I took the battery out before starting then i showed how to remove it later but it was not in all the time
storm builder - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 17
Insgesamt: 847
