Studenten-Wiki
Dieses Wiki wurde von einem der Studenten unseres Bildungsprogramms erstellt. Es wurde nicht von iFixit Mitarbeitern überprüft.
No matter what you do, you can't get your camera to turn on
The ON/OFF switch can get stuck. Make sure it is pressed all the way up.
If your camera won't turn on, change your batteries and see if that fixes the problem. AA batteries can be purchased from most stores.
The ON/OFF button may be broken. or circuitry connecting to the button. For help replacing the ON/OFF switch consult the guide here.
Pictures aren't clear
The subject that you are trying to capture may not be in the center of your view. Cameras focus on what's in the middle of their field. Try taking another picture with the subject at the focal point.
You may have changed your zoom faster than your camera could keep up with the focus. Try re-zooming in on your subject a little slower.
Parts of the lens may have broken. If you are turning the lens but the focus isn't changing, it may be a simple fix such as changing the plastic part. If the zoom does change as you turn the lens, the lens are faulty and will need to be replaced.
Pictures are not capturing or not showing up on memory card
Your memory card may be full. To free up memory space, consider downloading your pictures onto your computer using the USB cord, or deleting unwanted pictures and videos. If your memory card fills up too often, consider upgrading to a larger memory card or buying a back up one.
You may not be able to record pictures and videos because your camera doesn't know to! The button might be broken and needed to be replaced.
Videos are not capturing or not showing up on memory card
Memory card may be full. Free up memory space by either downloading your pictures onto your computer using the USB cord or deleting unwanted pictures and videos. If your memory card fills up too often, consider upgrading to a larger memory card or buying a back up one.
Unsatisfactory or no sound is coming from the device
Dirt or dust may have gotten into the device through the speaker holes. Using a needle, toothpick, and/or Q-tips, clean the outside of the device.
The speakers may be damaged and internal work needs to be done. Consult the speaker replacing guide here.
0 Kommentare
