Von Studierenden verfasstes Wiki
Ein tolles Team von Studierenden aus unserem Bildungsprogramm hat dieses Wiki erstellt.
If your Asus L410MA-TS02's battery is draining abnormally fast, follow this page for solutions.
Settings Are Not Optimized To Save Power
You can optimize your battery settings to maximize your battery life.
- You can optimize your window system settings by changing the following settings
- Reduce screen brightness: reducing the screen brightness is a good way to extend your batteries life
- Change power plan: Head to the power options menu in the window settings and select ASUS Recommend power plan. This will balance performance with energy consumption. If unavailable choose balanced.
- Adjust settings of the battery saver
- Adjust settings when device is powered on
Peripheral Devices Are Draining Power
- Connected devices such as USBs and Bluetooth devices may contribute to the battery drain. When not in use, you should unplug or power off such devices.
Too Many Running Applications
- Having too many applications running at once consumes more system resources and depletes your battery faster than normal.
- You can close applications that are no longer needed or not in use to help extend the battery's life.
- Manage background activity
- Check battery usage
Battery Failure
- The Asus L410MA-TS02 uses a lithium battery which degrades over time, especially if charged too often or exposed to excessive heat. If battery life has been draining fast this could be a sign that the battery’s life is ending.
- To replace the battery, use this battery replacement guide.
0 Kommentare
