Von Studierenden verfasstes Wiki
Ein tolles Team von Studierenden aus unserem Bildungsprogramm hat dieses Wiki erstellt.
Keyboard Not Responding
Presses to the keyboard are unresponsive or keys are missing.
Malfunctioning keyboard
Follow this guide to open the laptop and replace the keyboard.
Key(s) are stuck
Use compressed air to thoroughly clean the spaces underneath the stuck key.
Cursor speed needs adjustment
If Trackpad or the Trackpoint cursor travels slower than expected on screen, adjust cursor sensitivity in Control Panel.
Battery Depleting Quickly
The device shows a marked reduction in battery life.
Applications draining battery
Quit applications that are causing excessive energy drain in Windows.
Old or malfunctioning battery
Batteries have a limited lifespan or charge cycle. Replace the device’s battery.
Issues Reading CDs/DVDs
Dell Latitude E6320 optical drive is not functioning properly or unable to read discs.
Optical drive is dusty
Detach the optical drive from computer, open its tray, and wipe the lens. You might also spray the slot and the drive’s connectors (pins) with compressed air to remove any dust.
Reattach the optical drive back into the slot and make sure that it is properly locked in place. If problem persists, your optical drive may need replacement.
Optical drive needs replacement
Detach and replace the optical drive.
Distorted Screen Images
The computer screen has either dead pixels, a distorted image, or will not display images at all.
Screen is unplugged from device
Use this guide to remove the screen. Check that the cable connecting to the screen is properly fashioned and are plugged in properly for the screen
Screen needs replacing
Replace the screen.
Device is Overheating
The computer is unusually hot and possibly experiencing heat-related issues such as locking up, freezing, rebooting, or spontaneously shutting down.
Vent is on soft surface
Computer will overheat much more quickly on a soft surface, such as a blanket or your legs. Move computer onto a hard, flat surface.
Fan is dirty
Clean the vents using Compressed Air or replace the fan.
0 Kommentare
