Platzhalter-Seite (Stub)
This wiki page is a stub. Help us improve this page by adding information to it!
Von Studierenden verfasstes Wiki
Ein tolles Team von Studierenden aus unserem Bildungsprogramm hat dieses Wiki erstellt.
Computer Does Not Turn On
The laptop seems to not turn on nor run at all.
Motherboard replacement
- Check whether it is a CPU or Battery problem
- If there is no signal running through anything then it is recommended to replace the motherboard as a whole
Computer Overheats After A Few Minutes
The Laptop seems to overheat over just simply having the computer on after a few minutes.
Fan Solutions
- cleaning the fan from any dust or lint can improve the fan
- make sure to use the correct tool to clean the fan like the compressed air can
- If it is not spinning at all then it is time for a replacement
Computer Struggles to connect with the Wi-Fi
Wi-Fi disconnection keeps occurring and sometime issues with connecting to Wi-Fi initially.
Wi-Fi Solutions
- Restart your Wi-Fi system
- Restart your computer
- If the top 2 don’t work, it is recommended to replace the Wi-Fi card with a new one
The Keys/keyboard Does Not Respond To What I Type
Keyboard/Keys not responding. When I type multiple keys, it will not respond.
Keyboard Solutions
- Restart the computer
- clean all keys with a compressed air can and/or wipes
- If issue is not resolved then we the keyboard or specific keys needs to be replaced
Computer Is Always On Low Battery
The computer needs to be constantly plugged into the charger or else it will shut down in a few minutes
Battery solutions:
- Check if the charger is fully plugged into the outlet
- Check if the charging cable is still in perfect condition
- If it’s the computer battery, then a replacement is recommended.
0 Kommentare
