Von Studierenden verfasstes Wiki
Ein tolles Team von Studierenden aus unserem Bildungsprogramm hat dieses Wiki erstellt.
Computer Dies Quickly When Unplugged
Laptop power depletes quickly when not connected to power.
Computer only runs with AC Power Adapter
If the computer runs only while connected to AC power, via the AC power adapter, it is possible that the battery will no longer charge. Refer to the battery replacement guide for replacement procedures.
Faulty Battery
Many computers utilize a memory effect within the battery. If the battery shows full charge and then depletes rapidly, it is possible that the battery is no longer fully functional. Refer to the battery replacement guide for replacement procedures.
Keyboard/ Keys Not Functioning
The keys on the keyboard appear broken or missing, or will not respond.
Missing Keys
If you have a key that has fallen out, try reinstalling it by pressing it into the keyboard on its designated spot. If this does not correct the issue, refer to the [Ungültiger Anleitungslink] for steps to replace the keyboard.
Keys are Sticking
When keys cannot be pressed, there may be something below the physical key holding it up, and preventing it from being pressed down. Attempt to remove the key and make sure nothing is stuck below it. You may need to wipe the area underneath with a cloth or gently blowing away any debris. Once it is clean, snap the key back into position.
If you still experience keys that are sticking or cannot be unstuck, or keys that cannot be removed, please refer to the [Ungültiger Anleitungslink] for steps on replacing the keyboard.
Faulty Keyboard
After completing the above steps, the keyboard should now work correctly. If this did not fix your keyboard issues, it is possible you will need to replace the keyboard assembly or check for loose or faulty connections inside the computer. Refer to the [Ungültiger Anleitungslink] for instructions.
Cursor Does Not Respond On Screen
The keyboard, TouchPad, or ClickPad on your laptop is not working as expected.
Faulty TouchPad
If the TouchPad does not respond to any input by the user, there may be a loose connection or the TouchPad may be inoperable. Refer to the “TouchPad removal/installation instructions” guide for replacement.
Glitching or Black Display
The monitor is black or showing no image, but you are sure the laptop is turned on.
Faulty display
Turn off the computer. Connect the computer to a power source using the AC power adapter. Press and hold the Windows key and the B key at the same time while the computer is off. While still pressing both keys, hold down the Power button for one second, and then release the Power button and the keys. If the power LED light remains on, and the screen remains blank for about 40 seconds, you might hear beeping sounds. Afterwards, an HP BIOS Update screen displays, and the BIOS update beings.
If the screen remains blank after these steps, you may have a faulty monitor or have a loose cable connection. Refer to the “Monitor removal/installation instructions” guide for replacement.
System Slow To Respond
Over time, the computer has gradually slowed down and performance is faulty.
Clogged Vent
The most common cause of overheating is the accumulation of dust inside the laptop. Inadequate cooling from the fan inside your device can cause excess heat to build up inside the case which can damage components. The sound of the fan constantly running may indicate there is a problem with accumulated dust clogging the air vents.
Faulty Operating System
If the computer starts but fails to load the operating system, the hard drive may have failed. Please refer to “System Board removal/installation instructions” for replacement.
0 Kommentare
