Student-Contributed Wiki
Studenten-Wiki
Dieses Wiki wurde von einem der Studenten unseres Bildungsprogramms erstellt. Es wurde nicht von iFixit Mitarbeitern überprüft.
Hannspree Hannspad SN1AT71 Troubleshooting
Released March 2015
There is a crack in the crack in the lens of the camera, and all of the pictures have a large blurry streak through them.
The camera needs to be replaced. An iFixit step by step guide can be found here
The battery will be fully charged and then looses all of its charge in 15 minutes
The battery needs to be replaced. An iFixit step by step guide can be found here
No matter what you do, the Hannspad still shows a rotating logo
Press and hold the power button for 8 seconds to reset and reboot.
Use the hot key to enter into Android factory mode to recovery.
CLICK HERE for Android version 4.1.
CLICK HERE for Android version 4.2.
When you are in charge mode, you cannot turn on your tablet
Please check the battery. It must be over 14% charged. If not, please plug in the power adapter to charge. (The tablet must charge for over 30 minutes to power on)
Press the power button for 3 seconds then release it. The system will display the Hannspree logo about 3 seconds later.
Check if power adapter is inserted into the wrong place (for example,the earphone jack).
You can search for Bluetooth (BT) devices with an iPhone,but you cannot connect to it.
The iPhone system is iOS and the BT protocol is different from Android's. So normally, Android cannot support the iPhone's BT protocol.
Note: Other devices by Apple will have the same problem.
Note 2: Some special devices can support both iOS and Android's BT because they combine two BT protocol systems in one platform.
How many hours until the battery is full?
The charging time may take up to 10 hours the first two times the battery is charged.
May take up to 5 hours.
During charging, the battery icon on the screen will scroll.
When charging is complete, the battery icon will turn green and stop scrolling.
Note: It is suggested that you power off the device prior to charging.
You cannot unlock the screen after the tablet enters sleep mode
The on-screen button is not meant to be pressed. Instead of pressing, slide the button from the bottom to the top of the screen to unlock the tablet.
How do l read emails without downloading......also how do l delete unwanted emails
aliciawjackson - Antwort
How do l read my emails withuot having to download, also how do l delete unwanted emails
таблета иска да включи
Anito Gegova - Antwort
When I switch on my tablet all I get is the Hanna logo it fails to do anything else. Also when the charger is not plugged in it fails to switch off as restarts on its own but still only displaying the logo any idea what may be the problem? HELP
Stefan Lee Watkins - Antwort
I have the same problem
Hannspree -
Statistik anzeigen:
Letzte 24 Stunden: 9
Letzte 7 Tage: 32
Letzte 30 Tage: 165
Insgesamt: 8,602
