Von Studierenden verfasstes Wiki
Ein tolles Team von Studierenden aus unserem Bildungsprogramm hat dieses Wiki erstellt.
The Tablet Will Not Power On.
The tablet does not respond and shows no signs of power
Tablet Not Charged
Ensure that the tablet as been plugged in and left to charge for several hours before attempting to power on again.
Broken Power Button
Ensure the housing of the button has not come loose, using a small needle release the pressure by running it around the crease of the power button.
Faulty Battery
If the tablet only powers on when connected to the charger, then the battery may be faulty. Consider replacing the battery using this guide.
The Tablet Will Not Charge.
When connected to a charger, tablet does not charge.
Faulty Charging Cord
If the tablet is not charging, ensure the charging cord is not faulty. This will require an additional working charging cord from either the original manufacturer or equivalent.
Faulty Battery
If the tablet only powers one when connected to the charger, and fails to hold a charge when not connected, then the battery may be faulty. Consider replacing the battery using this guide.
Faulty Charging Port
If there is any damage to the charge port consider replacing following this guide.
The Tablet Keeps Turning On and Off
Tablet loads to Insignia logo before going black, and repeat.
Lodged Power Button
Look at the power button and ensure that it is not stuck pressed inwards. If button is stuck, check for any debris that may be holding the button. If nothing can be found, try using a small needle to unlodge the button.
Tablet Needs Factory/Hard Reset
Note: All user data will be erased and is not recoverable
Make sure tablet is connect to charger as dying during process could damage the device. Power the tablet fully off. Now press on HOLD the Volume + button. While holding the Volume + button, press the Power button until the screen lights up and shows the Insignia logo, then release the Power button ONLY.
Continue holding the Volume + button until one of two screens appear.
- A.) A screen appears with only an Android mascot in the background. If this happens let go of Volume + and press it one time. You should then see the screen shown in item 'B'
- B.) A list of options in the top left of the tablet screen.
Use the Volume - button to select “wipe data/Factory reset” and use the Power button to select it. Select “Yes — delete all user data” and select it with the Power button.
The Tablet Runs Slow
The tablet takes a long time to load applications or freezes occasionally.
Too Many Applications Running
Ensure that there aren’t too many applications running in the background by opening task manager by tapping the recent apps button and closing any apps.
Multiple Windows Open in Browser
Open web browser, and make sure there aren’t excessive windows open. Make sure to close any browser windows that aren’t currently in use.
Poor Storage Distribution
Uninstall and remove any unneeded apps, videos, pictures, etc. Open the settings > applications > manage applications. Select an app choose uninstall.
Lack of Sufficient RAM
Open the task manager by tapping the recent apps button and close open apps that aren’t in use.
Device May Need Factory Reset
To reset the device, first, go to the Menu and find and select Settings. Now choose Backup & Reset and tap Factory data reset. Then choose Reset device and select Erase everything to confirm the whole operation.
The Tablet Cannot Run Applications
When multiple applications are open, the tablet stops working or force shuts down applications.
Open the task manager by tapping the recent apps button, select close all applications.
Insufficient Processing Power
Ensure that there aren’t too many applications running in the background by opening the task manager by by tapping the recent apps button and closing any extra apps.
Tablet Runs Old Software No Longer Compatible With Current Software
Currently there is no fix for this issue. Message the manufacturer and request current software update.
2 Kommentare
My tablet stuck in the Insignia window and stay there. No possible way to restore to factory conditions.
Luis
LUIS J CABALLERO - Antwort
Has anyone tried installing Chrome FLEX OS on the P10W8100?
Peter Riniker - Antwort
