Von Studierenden verfasstes Wiki
Ein tolles Team von Studierenden aus unserem Bildungsprogramm hat dieses Wiki erstellt.
Computer will not charge/turn on
The laptop will not show any signs of turning on or charge
Broken cord /Damaged power adapter
If you notice that the charging indicator light on the laptop is flashing on and off, inspect power adapter cord to identify that there are no cuts into the wiring that won't allow the laptop to charge. If there are cuts in the power adapter's wiring, consider replacing the power adapter. Not fixing this problem right away could cause damage to the laptop battery due to it only intermittently charging.
If a damaged cord is not the issue, then check to make sure that the power adapter is plugged in. If power adapter is properly plugged in then make sure the charging indicator is on. If the indicator is not on, and the power adapter is plugged in, the adapter is faulty. Consider purchasing a new power adapter.
Dead/Uncharged battery
Make sure the power adapter is plugged into an outlet and the laptop properly. If the computer powers on only when the power adapter is plugged in, check the battery icon on the laptop display to see if battery is charging. Put your cursor over the battery icon and if the message says "Plugged in but not charging" and the power adapter is fine, then the device battery may be faulty. Consider purchasing a new laptop battery and using this guide.
Keys or keyboard is unresponsive
The computer doesn't respond when keys are pressed
Broken/Outdated keyboard
Make sure that drivers for the key board are up to date. Once drivers are updated then next, check to make sure that there are no small objects such as food blocking the keys from being pressed down. If there is blockage, consider purchasing some keyboard cleaner spray to get ride of the blockage. After cleaning the keyboard, if still no response, consider replacing the keyboard. Additionally, make sure that no liquid was spilled on the keyboard because this could cause a short. If liquid has been spilled on the keyboard and the keys are unresponsive, then the entire keyboard may be faulty. Consider replacing the keyboard.
Keys are missing
If keys are missing, then consider replacing them.
Laptop will not connect to Wi-Fi
When Wi-Fi is enabled the laptop will not connect to the internet
Outdated drivers
Make sure that your Wi-Fi is turned by placing the cursor on the Wi-Fi icon on laptop display screen. If Wi-Fi is already on and the computer cannot properly connect to Wi-Fi, go to the Lenovo website and download the appropriate driver for the correct operating system.
Unresponsive Wi-Fi card
If your Wi-Fi has been turned on, drivers are up to date, and you still cannot connect to Wi-Fi, then your Wi-Fi card may be faulty. Consider replacing the Wi-Fi card with this guide.
Computer performs slowly
The computer cannot perform basic functions quickly
Hard drive error
If RAM is replaced and the computer is still running slowly, freezing, or crashing frequently, the hard drive may need to be replaced. Damage to the hardware of the hard drive can be caused by the laptop overheating, dropping the laptop, or getting it wet. If the damage to the hard drive is physical, consider replacing the hard drive.
Another cause of hard drive error is damage to the software. If corrupt files were downloaded or if malware has infected the software of the hard drive, you may be able to recover the hard drive through a recovery disk. If you contact Lenovo with the make and model of the device, they will send the appropriate recovery disks needed. If the disks do not recover the information on the hard drive, consider using a hard drive recovery service.
Not enough RAM
If the computer performs basic functions slowly or crashes while attempting to do basic functions, you may have bad or insufficient RAM. Consider replacing the RAM on your computer.
No display
There is no video display even when the laptop is on or screen is damaged
Damaged screen
If screen is noticeably damaged and you can't identify what is being displayed because of discoloration, then the screen needs to be replaced.
Disabled display
If the laptop is turned on but the display screen is black, then check to see if the brightness is turned down. Navigate to the control panel on your computer and turn up the brightness. If screen is still black, it might be disabled, To enable the screen, press and hold the "Fn" key on the keyboard followed by "F2". This should fix the display.
Computer will not boot up
After turning on the computer does not go to the operating system
Not enough RAM
If the computer performs basic functions slowly or crashes while attempting to do basic functions, you may have bad RAM or insufficient RAM. Replace RAM on your computer.
Broken/Unresponsive hard drive
If RAM is replaced and computer is still running slow, freezes or computer crashes frequently, the hard drive may need replaced. Damage to the hardware of the hard drive can be caused by the laptop overheating, dropping the laptop, or getting it wet. If the damage to the hard drive is physical, consider replacing the hard drive.
CD/DVD won't play
"Once you insert a CD or DVD into the laptop, it will not play."
Disk is scratched
If the disc you inserted is noticeably scratched consider replacing the disc as this could be the reason the disc will not play.
Damaged optical drive
If your disc is not damaged and the disc still won't play, you should consider replacing the optical drive.
0 Kommentare
