Von Studierenden verfasstes Wiki
Ein tolles Team von Studierenden aus unserem Bildungsprogramm hat dieses Wiki erstellt.
Will your Lorex LHV210800 not turn on? Use this troubleshooting guide to help diagnose why.
The cable from the power adapter is loose or unplugged.
Make sure all of the cables in your devices are connected correctly either into the device itself or the wall, also make sure that the power adapter is securely connected to the back of the unit.
The power switch is set to “off”
Another cause could be that the power switch on your device is set to "off." Simply make sure that the power switch is set to "on".
Cables are connected, but the system is not receiving sufficient power
confirm that the system is powered on, meaning that the LED indicators on the front should be ON. If the unit is connected through a power bar or surge protector, something you can try is bypassing the bar and connecting the power directly to the wall outlet. Connect the power cable to another outlet maybe that one isn't working, also try the outlet with another device like (a lamp, or a charger)to make sure it's not your power cable.
0 Kommentare
