No Power
Your radio(s) won't turn on!!
Make sure the radio has batteries in it
Often times we overlook the simple things in life. If there aren't batteries in the radio, quickly find 3 AAA and insert them in the radio after removing the back cover. Don't worry, it happens to the best of us.
Also, be sure that you have placed the batteries correctly. (i.e. + to + and - to - terminals)
Try holding the power button
Firmly press and hold the power button for at least two seconds.
Pull the batteries out of the radio
Sometimes you may get lucky and be able to revive electronics by removing the battery for a certain amount of time and trying to power it on again.
Steps to take:
- Remove the back cover of the radio and then remove the batteries (detailed here)
- Wait at least 15 seconds
- Place the battery back into the radio and put the back case on
- Attempt to turn on the radio
Cannot Receive Messages
You aren't hearing any transmissions!
The radios in question must be on the same channel
You won't be able to receive/send messages to the desired radio(s) if the radios are not on the same channel. There are 22 GMRS/FRS channel choices.
How to select a channel:
- Power on the radio
- Press the MODE button and with the arrows, scroll through to the desired channel
- Press the PTT button on the side or the MODE button to confirm your selection
The radios must be within range of each other
Wouldn't it be nice if these radios could transmit from across the world? That would make phones obsolete! Unfortunately, the LXT118 has an 18-mile radius range, barring any interference.
There may be obstructions
Successful transmission, even within an 18-mile radius, may be prevented by obstructions such as buildings, mountains, or other structures. Try to get to an area with a more direct line of sight for transmission or simply a free area.
Display is Dim
Do not panic! In all likelihood you are not going blind.
Replace Batteries
If the display is dim but still working, your batteries are running low on power. They will need to be replaced with new batteries by opening up the back cover and switching out the old batteries for new ones.
For a more detailed explanation of the process of removing the batteries, view our guide here
Radio is not responding to button presses
Nothing is happening!
Unlock keypad
If the KEY LOCK icon is present on the display then the keypad will not respond to button presses. To unlock a locked keypad, hold down the KEY LOCK button on the far left for two seconds.
Reset the radio
Turn the radio off then wait ten seconds before turning it on again.
Radio Buttons are Stuck or Sticking
The buttons are slow to return to normal position or don't return at all!
Push repeatedly on the button to dislodge any foreign contaminants
Sometimes, small items like sand grains will hold the button down. Press firmly on the button to try to remove these annoying obstructions.
Prepare to clean!
Things you'll need:
- damp cloth
- cotton swab
- fingernail cleaner attachment (typically found on nail clippers)
Steps to take:
- Turn off radio and remove batteries
- Clean surface with damp cloth
- Rub cotton swab around edge perimeter
Press on button to see if contaminants have been dislodged
If not, carefully use the hook-end of the fingernail cleaner to rub around the perimeter. Use enough pressure to reach deeper around the buttons, but be sure not to use excessive force!
If the button is still stuck after this process, disassembly of the device will be necessary to reach behind the buttons. For this process, take a look at the disassembly photos and parts list.
18 Kommentare
Wife and I on same channel. LXT560 Series. She hears my chain saw running over hers, even though I’m not transmitting. I’m clear off in the woods and so she hears me in the distance live, and suddenly over her 2way. What gives?
dee VANAD - Antwort
That sounds like VOX mode auto transmitting the noise from your chainsaw. Turn off VOX and that should stop.
Adam Williams -
My husband took his about a mile away and tried to talk to me. I couldnt hear him at all, just a little static but he could hear me really clear. Is there a setting we need to change on one of them?
angelsamsel - Antwort
My midland X talker will not unlock power comes on set on the charger for about four minutes and an error comes up UB I’ve tried everything on this planet to get it Unlock any help would be appreciated
Phillip - Antwort
When we hold the button down to talk, the receiving midland xtra talk lxt600 it doesn’t receive messages because it sounds like the other person is repeatedly pressing the button, but they aren’t.
Alexis Cravatt - Antwort
