Von Studierenden verfasstes Wiki
Ein tolles Team von Studierenden aus unserem Bildungsprogramm hat dieses Wiki erstellt.
Computer will not power on.
When you press the power button, neither screen nor computer will power on.
Battery Replacement
This can be done by looking at the bottom of the computer in the back and pull the two clips on the sides and it should come right out. Then insert the battery back in place and try to turn on your computer
Overheating Laptop
Laptop will power off after a certain time or not turn on at all.
Faulty Fan
Check for dust in the fan, located on the bottom of the laptop. The Toshiba Tecra M11 can overheat because of an unnecessary amount of dust stuck in the fan, causing the fan to lose its cooling power. In order to be able fix this, you have the option of doing two things: Get a compressed air duster to blow it out or take the laptop apart an clean it.
Insufficient Thermal Paste
The thermal paste is what helps keep the overall temperature of the laptop. Lack of paste between the heatsink and processor. For more help on how to change the thermal paste visit Toshiba Satellite C850 Thermal Paste Replacement
Frozen or Unresponsive Screen
The monitor appears frozen and won’t react to any action taken using the touchpad or keyboard.
Turning Touchpad on or off
Hold down Fn and press f9 to see if touchpad was previously turned off. Test touchpad. If touchpad doesn’t work, hold down Fn and click f9 again to turn it back on.
Try a “Hard Reboot”
Remove the battery & unplug the wall cord from the Laptop. Hold down the power button for 30 seconds. Reinsert the battery and reconnect laptop to wall cord. Then, try to restart the laptop.
4 Kommentare
i did the remove battery & unplug the wall cord from the laptop the i did the hold down the power button for 30 seconds the i reinsert the battery an i reconnect the wall cord to my laptop then i restart my laptop my screen was blank for a couple of seconds then i seen on the screen automatic repair and then the screen went blank again and is still blank
Mary Beth Griffith - Antwort
i tried this yesterday with the battery thing taking it out and putting it back in and restarting my lap top and i got the same message as i did today yesterday what else can i do to get my laptop to turn on and not get that message and have that blank scren????????????
i need a computer tech please!!! to help me through this
what is the Fn?
