Likely Cause: Battery is dead
Solution: Charge battery for a few hours. If the phone still doesn’t turn on after
charging the battery, it is likely that the battery needs to be replaced. If that is the
case, follow the repair guide for instructions on how to replace the battery.
Disassembling Samsung Gravity SGH-T459 Battery
Likely Cause: Back cover is damaged
Solution: Replace the back cover. Follow the repair guide for steps on how to
replace the back cover. Disassembling Samsung Gravity SGH-T459 Back Cover
Likely Cause: Rear case is damaged
Solution: Replace the rear case. Follow the repair guide for steps on how to
replace the rear case. Disassembling Samsung Gravity SGH-T459 Rear Case
Likely Cause: Camera is dirty or damaged
Solution: Follow the repair guide for steps on how to remove the back cover to
assess the camera. Disassembling Samsung Gravity SGH-T459 1.3 megapixel camera
Likely Cause: Keypad is damaged
Solution: Follow the repair guide for steps on how to remove the back cover and
access the keypad. Disassembling Samsung Gravity SGH-T459 Keypad
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,017
