Einleitung
This guide details how to replace the battery in a DualSense Edge PlayStation 5 controller. If your controller won't power on or is draining quickly, follow this guide for battery replacement.
A functional battery provides power to your controller. Unfortunately, all batteries will drain after going through a repeated amount of charge cycles. If you notice that your charged battery is draining more quickly than usual or, even worse, has ceased to hold a charge at all, you should replace your battery.
If your battery is swollen, take extra care and handle it with caution.
Make sure the controller is turned off before you begin.
Was du brauchst
Use the opening pick to push the release latch on the back of the controller.
Slide the opening pick along the left and right inner trim to release the clips that secure the case.
Turn the controller around and continue sliding the opening pick along the trim to release the remaining clips.
Use a Phillips #00 screwdriver to remove the two 6.5 mm screws from the L1 and R1 button enclosures (one screw on each side).
Use your screwdriver to remove the seven 6.5 mm screws from the back of the controller.
Pull the lever to the left and lift up to detach it from the controller.
Be careful with the tiny spring attached to the lever, as it is easy to lose once detached.
Insert an opening pick between the front and rear casing and gently pry them apart.
Use your opening pick to lift the battery from its enclosure and expose the wire connection.
Place your opening pick under the wire housing, and pull it upward toward you to disconnect the battery.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
