Zum Hauptinhalt wechseln
Repairing an FJ-3LED Globe Electric Push Light
Was du brauchst
  1. Repairing an FJ-3LED Globe Electric Push Light, Repairing an FJ-3LED Globe Electric Push Light: Schritt 1, Bild 1 von 3 Repairing an FJ-3LED Globe Electric Push Light, Repairing an FJ-3LED Globe Electric Push Light: Schritt 1, Bild 2 von 3 Repairing an FJ-3LED Globe Electric Push Light, Repairing an FJ-3LED Globe Electric Push Light: Schritt 1, Bild 3 von 3
    • Lift the black lid off of the battery slot and remove the batteries.
  2. Repairing an FJ-3LED Globe Electric Push Light: Schritt 2, Bild 1 von 3 Repairing an FJ-3LED Globe Electric Push Light: Schritt 2, Bild 2 von 3 Repairing an FJ-3LED Globe Electric Push Light: Schritt 2, Bild 3 von 3
    • Use the Phillips #1 screwdriver to remove four 1.4 mm screws from the back of the light.
    • Take the black part out and separate it from the white case.
  3. Repairing an FJ-3LED Globe Electric Push Light: Schritt 3, Bild 1 von 1
    • Identify which part of the lamp is broken.
    • in this case, one of the connections in the circuit had been disconnected.
  4. Repairing an FJ-3LED Globe Electric Push Light: Schritt 4, Bild 1 von 1
    • For tips on Soldering, see How to Solder and Desolder Connections.
    • Attach the disconnected wire to its joint using solder and iron tip. Place the tip of the soldering iron against the solder pad.
    • Melt enough solder onto the solder pad.
    • Remove both the solder and the soldering iron tip from the connection as soon as enough solder melts onto the pad.
    • Don't forget to use gloves.
  5. Repairing an FJ-3LED Globe Electric Push Light: Schritt 5, Bild 1 von 2 Repairing an FJ-3LED Globe Electric Push Light: Schritt 5, Bild 2 von 2
    • Push the circuit into its place.
    • Click the button to see if the wires are connected .
  6. Repairing an FJ-3LED Globe Electric Push Light: Schritt 6, Bild 1 von 2 Repairing an FJ-3LED Globe Electric Push Light: Schritt 6, Bild 2 von 2
    • If the lights turn on, the connection is perfect in the circuit and the disconnected joint is now connected.
    • Place the white case on top of the circuit and close it with the Phillips #1 screwdriver.
Abschluss
Rojina Saberi
133 Reputation
1 Anleitung geschrieben
York University, Team S1-G23, O'Regan Summer 2021 Mitglied von York University, Team S1-G23, O'Regan Summer 2021
YORK-O'REGAN-SU21S1G23
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 14
Insgesamt: 347
