Einleitung
It is common for a phone screen to break. Dropping your phone or dropping something onto your phone can cause screen damage. Luckily, replacing your Samsung Galaxy J7 screen is easy, and more affordable than paying someone else to fix it. This guide will teach you how to remove your phone's screen.
Before you begin, check out what you should know before you fix Samsung phones.
If you come across any issues, check out the troubleshooting page
Was du brauchst
Insert a Jimmy tool under one of the corners of the display and gently raise the display.
29 weitere Nutzer:innen haben diese Anleitung absolviert.
