Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-W510 LCD Screen Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-W510 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 1 von 1
    • Place the Sony Cyber-shot DSC-W510 on the magnetic project mat. This will help keep the small screws organized.
  2. Sony Cyber-shot DSC-W510 LCD Screen Replacement, Unscrew: Schritt 2, Bild 1 von 2 Sony Cyber-shot DSC-W510 LCD Screen Replacement, Unscrew: Schritt 2, Bild 2 von 2
    • Using the Phillips #00 screwdriver, unscrew the outside screws from the frame of the camera.
    • There are five screws on the bottom of the camera and two on the side.
    • If the screws are stripped, visit the Removing a Stripped Screw Guide.
  3. Sony Cyber-shot DSC-W510 LCD Screen Replacement: Schritt 3, Bild 1 von 2 Sony Cyber-shot DSC-W510 LCD Screen Replacement: Schritt 3, Bild 2 von 2
    • Pry open the screen frame using a plastic opening tool.
    • It may be necessary to start by prying at one end of the screen and moving around the edge of the screen frame, until it pops out.
  4. Sony Cyber-shot DSC-W510 LCD Screen Replacement: Schritt 4, Bild 1 von 2 Sony Cyber-shot DSC-W510 LCD Screen Replacement: Schritt 4, Bild 2 von 2
    • Using the screw driver, unscrew the one screw on the control panel board.
  5. Sony Cyber-shot DSC-W510 LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Gently unplug the control panel from the motherboard outlet.
  6. Sony Cyber-shot DSC-W510 LCD Screen Replacement: Schritt 6, Bild 1 von 2 Sony Cyber-shot DSC-W510 LCD Screen Replacement: Schritt 6, Bild 2 von 2
    • Using your hands, pry open the LCD screen from the metal board.
    • Gently unplug the LCD screen from the motherboard.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
kyle
424 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 18
Insgesamt: 1,485
