Zum Hauptinhalt wechseln
Toshiba Satellite C55D-A5108 Heat Sink Replacement
Was du brauchst
  1. Toshiba Satellite C55D-A5108 Heat Sink Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108 Heat Sink Replacement: Schritt 2, Bild 1 von 1
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108 Heat Sink Replacement: Schritt 3, Bild 1 von 1
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108 Heat Sink Replacement, Hard Drive: Schritt 4, Bild 1 von 1
    • Remove the Phillips #0 screw from the memory cover.
  5. Toshiba Satellite C55D-A5108 Heat Sink Replacement: Schritt 5, Bild 1 von 1
    • Grasp the side of the hard drive opposite the circular battery, and carefully pull out the drive by moving it away from the circular battery.
  6. Toshiba Satellite C55D-A5108 Heat Sink Replacement, Back Cover: Schritt 6, Bild 1 von 3 Toshiba Satellite C55D-A5108 Heat Sink Replacement, Back Cover: Schritt 6, Bild 2 von 3 Toshiba Satellite C55D-A5108 Heat Sink Replacement, Back Cover: Schritt 6, Bild 3 von 3
    • Remove the 16 screws holding the back cover with a Phillips #0 screwdriver.
    • Pry the cover off with an opening tool.
    • Gently remove the cover with your hands and place to the side.
  7. Toshiba Satellite C55D-A5108 Heat Sink Replacement, Heat Sink: Schritt 7, Bild 1 von 2 Toshiba Satellite C55D-A5108 Heat Sink Replacement, Heat Sink: Schritt 7, Bild 2 von 2
    • Remove the four Phillips #0 screws from each corner of the heat sink.
    • Gently lift the heat sink out of the computer.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ryan Smith
187 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 Mitglied von UMass Dartmouth, Team S1-G5, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G5
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 286
