Zum Hauptinhalt wechseln
Toshiba Satellite P55-A5312 Battery Replacement
Was du brauchst
  1. Toshiba Satellite P55-A5312 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite P55-A5312 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
  2. Toshiba Satellite P55-A5312 Battery Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite P55-A5312 Battery Replacement: Schritt 2, Bild 2 von 2
    • Locate the battery, which is in the top right hand corner of the laptop.
    • Remove all the 2.5x6mm screws that secure the battery with a Philips 00 screwdriver.
  3. Toshiba Satellite P55-A5312 Battery Replacement: Schritt 3, Bild 1 von 1
    • Locate the intersection of the wires that connect the battery to the motherboard.
    • Unplug these wires by gently pulling on the white plug, as shown in the picture.
  4. Toshiba Satellite P55-A5312 Battery Replacement: Schritt 4, Bild 1 von 1
    • Carefully remove the speaker that is placed above the battery by gently pulling upward from one end. Be careful not to break a wire.
    • Move the speaker elsewhere while replacing the battery (do not disconnect it).
  5. Toshiba Satellite P55-A5312 Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the battery from the laptop after it has been completely disconnected.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
ohatae
294 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 9-1, Banghart Winter 2017 Mitglied von Cal Poly, Team 9-1, Banghart Winter 2017
CPSU-BANGHART-W17S9G1
3 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
The repair guide was great. Got right through the battery change procedure. only took about 25 minutes start to finish. I was told by a friend to try this as a way to bypass the forgotten password at startup of the computer so that I could put a new password in it. The result is that did not work. Can anybody tell me how to do this
Roy Conrad - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 22
Insgesamt: 5,823
