Zum Hauptinhalt wechseln
Toshiba Satellite U840W Processor Fan Replacement.
Was du brauchst
  1. Toshiba Satellite U840W Processor Fan Replacement., Toshiba Satellite U840W Disassembly Guide: Schritt 1, Bild 1 von 2 Toshiba Satellite U840W Processor Fan Replacement., Toshiba Satellite U840W Disassembly Guide: Schritt 1, Bild 2 von 2
    • There are ten 5mm screws surrounding the edge of the cover.
    • A rubber cap covers the eleventh 5mm screw (in the center).
    • Remove the screws using a Phillips #00 screwdriver.
  2. Toshiba Satellite U840W Processor Fan Replacement.: Schritt 2, Bild 1 von 3 Toshiba Satellite U840W Processor Fan Replacement.: Schritt 2, Bild 2 von 3 Toshiba Satellite U840W Processor Fan Replacement.: Schritt 2, Bild 3 von 3
    • Pry between the casing and cover using a plastic wedge tool.
    • Use the wedge tool to move along the case & slowly pry it open.
    • The wire for the 12v charging port connects the cover to the casing.
  3. Toshiba Satellite U840W Processor Fan Replacement.: Schritt 3, Bild 1 von 3 Toshiba Satellite U840W Processor Fan Replacement.: Schritt 3, Bild 2 von 3 Toshiba Satellite U840W Processor Fan Replacement.: Schritt 3, Bild 3 von 3
    • Disconnect this connector from the motherboard to avoid damaging the motherboard or charging port cable.
  4. Toshiba Satellite U840W Processor Fan Replacement.: Schritt 4, Bild 1 von 1
    • Disconnect the battery.
    • Hold down the power button for ~10 seconds to discharge any stored electricity from the motherboard.
  5. Toshiba Satellite U840W Processor Fan Replacement., Processor Fan: Schritt 6, Bild 1 von 2 Toshiba Satellite U840W Processor Fan Replacement., Processor Fan: Schritt 6, Bild 2 von 2
    • Remove the three 3mm screws using a Phillips #00 screwdriver.
  6. Toshiba Satellite U840W Processor Fan Replacement.: Schritt 7, Bild 1 von 2 Toshiba Satellite U840W Processor Fan Replacement.: Schritt 7, Bild 2 von 2
    • A plastic prying tool can be used to help you remove the fan.
    • Plastic wire guides hold the wire in place. Manipulate the wire out from these guides.
  7. Toshiba Satellite U840W Processor Fan Replacement.: Schritt 8, Bild 1 von 2 Toshiba Satellite U840W Processor Fan Replacement.: Schritt 8, Bild 2 von 2
    • Remove the connector from the motherboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Tony Aprile
118 Reputation
1 Anleitung geschrieben
Gateway, Team S1-G1, Saknee Spring 2019 Mitglied von Gateway, Team S1-G1, Saknee Spring 2019
GCC-SAKNEE-S19S1G1
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 324
