Loud knocking sound in spin cycle?
Hi, I'm trying to figure out this loud knocking sound that happens when my Kenmore elite goes in to any spin cycle. It's even worse when it's in the high speed spin.
I've pulled off the back of the machine inspected the motor belt and pulley. It all looks fine. I also made sure that its level. But it still makes the noise. Any info will help.
Thanks
John
Ist dies eine gute Frage?
16 Kommentare
Thank you for that info. I've been searching for the spider assembly on a Kenmore site and cant find anything under that name. Is there a def name for it? Also it is a front load washer. Thanks.
von John Warren
Is it an an unbalanced load?
von Reagan Games
I don't think so because when it empty and I give it a spin I can hear it hitting the outer tub @ one spot. It's kind of a scraping sound when empty and spun by hand.
von John Warren
I realized this problem only happened when the washer was draining, so I removed the back panel and drain pump and discovered a penny was hitting the propeller, which was causing this noise during the spin cycle. Don’t ask me how the penny got through washer, but that was my problem that has happen to me at least three times. Guess what, on the bottom of the tub (clear plastic), I can see two more pennies that haven’t got to the drain pump yet. My wife and I discovered this happens every time our college son comes home to visit and washes his clothes.
von kr smith
Is there a reasonable fix for that aside from replacement?
von Christopher Malley
11 weitere Kommentare anzeigen
