Zum Hauptinhalt wechseln
Repair and disassembly guides for Sony DVD players.
65 Fragen Alle anzeigen
DVD player is not reading DVDs or CDs
Sony DAV-DZ690K
I own this four years old Sony Home Theatre system. I noticed recently, it is not reading either DVDs or CDs. When I insert a DVD, it takes a while to read, but shows 'No disc'. The tray simply opens on its own.
I appreciate your help to solve this problem.
Thank you so much in advance.
Narni
Ist dies eine gute Frage?
Bewertung 5
2 Kommentare
Mine takes awhile loading then says can not play this disc.
von
I wanted to know the spray that is used in cleaning of the lens inside the DVD
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Narni, sounds like either a dirty laser or a burned out laser. Try one of the commercially available lens cleaners. If that does not work you may have to disassemble your player and clean/replace the lens assembly. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Thanks for the advise. I bought a lens cleaner and tried. The tray is just opening on its own. The player is not reading the discs.
Any advise is welcome!
von
Thanks for the advise. I bought a lens cleaner and tried. The tray is just opening on its own. The player is not reading the discs. Any advise is welcome!
von
Try another disc or try another drive to make sure which causes the problem. In most cases, it’s a scratched DVD or a dirty drive. This post has shown all the possible reasons and fixes.
Bewertung 0
Push power protector
Bewertung 0
1 Kommentar:
Push
Reasonpower protector not working
von
Antwort hinzufügen
Narni wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 20
Insgesamt: 13,649
