does not start . how to check why
does not start. what to check to see why
Ist dies eine gute Frage?
David,
More info would help to point you in the right direction.
Basically you need Ignition, Compression and Fuel
Compression- Is engine turning over or cranking (battery, connections, starter, relay)
Fuel- Are you getting gas to cylinders (fuel, fuel pump,injectors and sensors)
Ignition- Spark to to cylinders (spark plugs, ignition coil, plug wires and sensors)
Hope this gives you a direction, Glenn
David,
Check this out
https://wiki.bentleypublishers.com/pages...
Glenn
War diese Antwort hilfreich?
hi Glen > this will be my first time working on one of these cars . No problem turning it over . If there is spark then start at the fuel . What pressure should the fuel be
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 15
Insgesamt: 634
