Zum Hauptinhalt wechseln
Reparaturanleitungen für Fahrzeuge der Marke Honda.
1396 Fragen Alle anzeigen
Car jerks while accelerating.
My 2002 Honda Accord with 82500 miles on it jerks a bit when accelerating. Nothing happens to the speed but the rpm drops and then again increases and then the car picks up speed. What might be the problem ?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 9
13 Kommentare
what engine size is in your Accord? Any change in gas mileage? When was the last service?
von
The engine size is 2.3L 4Cyl., I haven't really looked at the gas mileage. The last service was done in May when the car had around 80K miles and now the car has around 82.5K miles.
von
Could i buy a transmission with a 2 year warranty and have it installed?
von
My hunda car won't pick up as I engaged it into drive mood even when i matched down the acceleration pedal. What might be the cause?
von
i have the same problem how did you fix it ?
von
8 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
6 Antworten
Gewählte Lösung
Could be a knock sensor or a loss of air inside the air box/tube that goes to the intake manifold. I would have the check engine light checked; just because it isnt on doesn't mean there isn't a code in the system. Most of the errors would give you a check engine light, so it might just be a matter of time till it comes on.
My Subaru had a faulty knock sensor => loss of power when accelerating
Mazda had a break in air duct => loss of power when accelerating
War diese Antwort hilfreich?
Bewertung 4
1 Kommentar:
Yeah I got the knock sensor code and p0502
von
Change the ignition coils and your problem will be fixed .Before changing coils insulate them by pvc tape
first and install them back in and if you problem decreases it will be confirmed ignition coils are bad now .so just change them .
Bewertung 2
1 Kommentar:
My 2005 Honda pilot jerks when I take off on freeway and after shifts fine runs good some days I have to turn off because blinking lights like the D and a ! I turn off then on and it's fine what can it be
von
The Driver ? Joke LOL
I would start with New Plugs / Oil/Air/Fuel filters. is the check engine light on ?
Bewertung 1
1 Kommentar:
No the check engine light isn't on.
von
my Friends Car was like that.. It would have almost NO power also.
it was the O2 Sensor that went bad and needed replacement.
weird eh?
Bewertung 0
5 Kommentare:
Hi my 2000 Honda Accord is jerking when I take off from sitting still I step on the gas and it jerk pretty hard then it drive I come to a red light it stops and when I get ready to go it jerk what can this be my car has almost 100000 thanks for any info
von
What does the belt look like?
von
Mines does the same thing it starts blinking D and a ! I pull over turn it off turn back on and it runs fine after that what can it be
von
Speed sensor
von
@Lewis Johnson speed sensor
von
Had the same problem changed airfilter in Honda civic ex 56plate sorted
Bewertung 0
1 Kommentar:
i have honda civic 2006 d light is blinking and car is jerking when it comes to stop sing
how did you fix your car ?
von
speed pick up problem
Bewertung 0
Antwort hinzufügen
neha wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 75
Letzte 30 Tage: 214
Insgesamt: 86,941
