when I turn on my camera it says lens obstruction
Ok so when I try turning my camera on it says lens obstruction and the lens wont come out and after awhile it turns off.
Ist dies eine gute Frage?
Juanita Gonzalez, this is most likely caused by a stuck lens. These errors are more common with an extended lens, but can also appear in a retracted lens. Take a look on here to see how to deal with it. It will be the same for most brands. If this does not work, you may be looking at replacing the lens itself. Since you did not tell us what model your camera is, we can not provide any further details with that. Hope this helps, good luck.
War diese Antwort hilfreich?
my camera is a kodak easyshare c195 14 megapixel with 5x optical zoom.. any tips??
Mine is a Kodak Pixpro AZ251, and I know I deopped my camera, and after I dropped it It said lens obstruction, restart camera. what do I do now?
Im having the same problem with my GE X500 Camera..pls need a solution .thank u
i have the same camera with the same problem
my camera doesn't work and it always says that lens obstruction. what should i do?
Can not get my Len back in due to lens obstruction and will not stay on
jesse ross make and model for your camera? What have you tried?
I have the same problem. How do you fix it?
Letzte 24 Stunden: 6
Letzte 7 Tage: 47
Letzte 30 Tage: 196
Insgesamt: 19,497
5 Kommentare
I had experince too
von noel
My camera brand GE 14.1 megapixel E1450W
von noel
i tried to turn on my kodak pixpro az252 and it says lens obstruction and turns off how do i fix it
von Marci Faro
Mine is a BRAND NEW Kodak PIXPRO AZ252 Bridge Camera. I had just opened it the day I bought it and it said lens obstructed Restart camera and then it shut off. I am really mad. The shutter and lens does not even come out.
von Juliann (Esther) Headrick
Same how do you fix it I have the FZ41
von Imissbabycoco Resendiz
