Zum Hauptinhalt wechseln
Modern rebirth of John Cooper's classic automobile, made by BMW.
13 Fragen Alle anzeigen
Cabin air vents not supplying any air.
I own a 2004 Mini Cooper S, and no air will come out of the dashboard air vents. All air seems to be vented through the defrost vents. I have checked all fuses, cabin air filter, and even tried the "off button/ '+' " system check with no faults found. Any suggestions would be welcome.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Most cars have either a cable or a motor system to alter the air dampener valve/s.
When you alter the setting do you hear any noise of a motor or the thump of the valve closing? My Ford had foam rubber as a seal around the dampener door it got sticky so it wouldn't open.
You may need to locate the valves under the dash heater/cooler box. Try moving them manually.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Jay wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 1,401
