Zum Hauptinhalt wechseln
The CFS-204 is a 90's style analog AM/FM radio and cassette tape player. It can be powered by either six C-cell batteries or A/C power from a standard wall outlet.
6 Fragen Alle anzeigen
How can I get the buttons on my radio un-stuck?
I pushed the pause button on my radio and now I can't get it to pop back out. I have tried pushing it several times and it seems to be jammed in a permanent downward position.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
If the button is stuck, try to use something small to clean around the button; it may have dirt built up around it causing it to be stuck. Use something small such as a paper clip or a cotton swab to clean around the button. If this does not work, you may need to disassemble the device. If you need more information, see the link here to our Troubleshooting page.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Brittany Patterson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 66
Insgesamt: 21,961
