Steering wheel shakes when braking
When braking from speeds over 50 mph, typically under light braking such as slowing down for a stoplight, the steering wheel shakes back and forth from side to side.
Ist dies eine gute Frage?
If it is the steering wheel shaking, it is most likely a front brake issue. You can often visually see through the wheels to see the pads, but there may not be much you can see. A shaking usuaully indicates an out of round or thickness variation condition with the rotors. Special measurement tools are necessary to check this, but many times pad and rotor replacement is feasible since it is often needed by this point anyways.
If after replacing the pads and rotors you still have this issue, it is recommended to take it to a professional for further diagnosis.
See the 2011 Dodge Journey Troubleshooting guide for more help
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 31
Insgesamt: 2,591
