Zum Hauptinhalt wechseln
Floor lamps are lights that sit on the floor. They are not table lamps, which are designed to sit on tables. Floor lamps are usually taller than table lamps.
22 Fragen Alle anzeigen
shorten heigth of poles
have a halogen floor lamp. someone shortened it now i need to add pole back in for height.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
You should be able to get replacement pieces for the pole (depending on how thick the pole is or if there are any decorative aspects) from any home improvement store. Home Depot, Lowe's, Rona. You will have to check to see if you have enough power cord available for the extension though. Fixing something like this is not for the faint of heart so if you are unsure ask someone in the lighting dept on tools you will need etc.
Hope this helps
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
shermoonlight62 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 14
Insgesamt: 1,206
