Zum Hauptinhalt wechseln
Gateway makes quality notebooks, laptops, and netbooks. Owned by Acer Group.
220 Fragen Alle anzeigen
My gateway laptop is not connecting to wireless internet
i think my wireless card is broken .its not working but my wired internet is not working . please help ?
should i replace my wireless card ?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 8
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
hello,
there should be a sliding switch on the very side or back of it, bottom part with keyboard, check to make sure its in the on position. If it is, try looking for a Reset Wifi driver on gateways website, it would be able to set the "wall" of wifi back up.
War diese Antwort hilfreich?
Bewertung 7
just try following steps that might help -
just reset the adapter settings in wireless device and update the wireless driver and make sure time and date is also correct in computer . also check the wireless password and for more visit gateway websites help section and see if this works for you . let me know if you need anymore help
Bewertung 2
I was told locally that this is an endemic problem and can't be repaired. Can a used computer be scavenged for the bad part.?
Bewertung 0
1 Kommentar:
My laptop won't work either wired or wi fi. If it is just the io card can that be replaced?
von
Antwort hinzufügen
Richrad wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 53
Insgesamt: 6,065
