Zum Hauptinhalt wechseln
A tablet released by Hisense in 2014, identified by model number E2281.
36 Fragen Alle anzeigen
Why does my battery not hold a charge?
I have been charging my device for the past five hours and yet it is still not fully charged. My outlet is working and I have correctly plugged in the charger but still nothing. What can I do to fix it?
Ist dies eine gute Frage?
Bewertung 11
1 Kommentar
The answer given does not fit the question. Your battery's suck. Just tell the truth about your product hisense
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
If the tablet does not charge, try wiggling the connector. If the tablet continues to not charge or only charges when the chord is held in a specific position, then you need to repair the USB port.
If you are having trouble fitting the charger into the USB port, you may need to remove the connector and check if there is any debris in the port. If so, then clean out the port and try connecting the charger again. If the charger still does not fit, there is another underlying issue.
War diese Antwort hilfreich?
Bewertung 1
Your battery is most likely shot. Good luck finding a replacement. I suggest a different manufacturer
Bewertung 0
1 Kommentar:
Actually the battery is for sale online. I'm assuming you knowhow to open the plastic case without breaking it. Use a plastic guitar pick at the seam. The batt has numbers 606090 on it and it is 3.7volt 2400mah. And so obviously if your not tech inclined then dont attempt it. The batt stops holding a charge. It's a cheap batt they installed at factory
von
Antwort hinzufügen
Katherine wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 2,573
