Zum Hauptinhalt wechseln
Released December 2013. Identified by model number MFC142EN. Repair for this device requires common prying tools and a soldering iron.
4 Fragen Alle anzeigen
How do I fix the buttons on my LexiBook Tablet One?
I recently dropped my tablet and not only did the screen crack, but now I am having trouble controlling the volume and turning the device on and off. I believe the buttons might have gotten dislodged.
How would I re-seat these buttons?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
This is a very easy fix.
The first thing you want to do is remove the back plate. This can be done with a prying tool. If you do not have a access to a prying tool you can actually use a credit card or an appropriate equivalent. If you stick the tool/card in between the screen and backing where the two come together you can work your way around the device, undoing the clips that hold it together. Once doing so be careful of not pulling out the speaker. Once you have the device open you can re-seat the buttons and put the backing back on.
For a more detailed description with pictures please refer to the troubleshooting page at LexiBook Tablet One Troubleshooting
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Daniel wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 153
