Which RAM is compatible to upgrade Toshiba Satellite C850 X0011
My Toshiba presently has a 2GB RAM.
Can you please tell me which RAM is compatible with this laptop? 1300 MHz or 1600 MHz will that make any difference?
Ist dies eine gute Frage?
Tp start with here is the Toshiba Satellite C850 Users Guide: User Guide.
Here's the spec sheet: Toshiba Satellite C850
Your system uses: PC3-10600/12800 DDR3-1333 SODIMM 204pin memory. As to the memories speed You can use a faster rated module (1600MHz) but you shouldn't use a slower than what is spec'ed. In your case the speed needed is 1333 MHz.
Here's a little more detail on DDR3 memory: DDR3 SDRAM
War diese Antwort hilfreich?
With the correction of the model info: The X0011 model is newer and requires the 1600MHz RAM.
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 19
Insgesamt: 9,960
