My computer shuts down soon after it starts up!
when i press the start button in the laptop it takes much time to open (more than 2 minutes) then it shuts down by its own i don't press any button
Ist dies eine gute Frage?
When you write "time to open" I assume you mean the system boots up and loads your OS, but suddenly it shuts down. Is it correct?
If so, check you system fan, because the problem seems to be caused by an overheating and the laptop shuts down to prevent damages.
Other thing you can check is the thermal paste condition, or even if the heat sink is correctly screwed to the mounting holes.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 16
Insgesamt: 442
1 Kommentar
Mine, if run on battery is won't shutdown but when plug it shutdown any solution pls
von Abiodun Bamidele
