How to replace the timing belt
how to timing the car?
Ist dies eine gute Frage?
Oh dear you need the special can locking kit with the tdc locking pins ,Reno's are a ##&&% to work on I know I got a modus 1.6 its the same set up ,they also use a dephaser cam gear so if it starts to make a rattling sound on start up get it changed , only use synthetic oil and change the filter twice a year because they are so small , buy a can of silicon spray and spray every electrical connection and fuse box ,these things are prone to damp ,
Hope it helps you ,good luck !
War diese Antwort hilfreich?
There is a perfect book for repairing this car on your own. Give it a try
I changed the timing belt a few years ago. I didn't use any locking kit. The hole to lock it is inaccessible. It looks possible in the Haynes book but it isn't. I marked up everything with a white pen and took the chance of nothing moving. It worked fine and I saved 500£/€\$. I took my time when I didn't need the car.
You cannot do this with the diesel engine variants without running a real risk of the camshaft moving relative to the camshaft Marking the parts simply doesn't work as the crankshaft pulley is not keyed the the crankshaft on the diesels.
@cjrc your diesel has a timing belt? What engine is this exactly?
@oldturkey03 1.5
@cjrc Awesome and I just found the tools for it as well. I thought it was uncommon for a Diesel to have a belt vs a chain but I guess Nissan/Renault built a pretty good engine with it.
Letzte 24 Stunden: 12
Letzte 7 Tage: 57
Letzte 30 Tage: 206
Insgesamt: 11,334
1 Kommentar
Hi, my 2004 renault megane is making a grrrr sound when idling and driving.
My belt has alota fine cracks. What can be the problem?
von moegsienjacobs
