lights up but no heat I have not used it much
I plug in and light comes on. but no heat I have only used it a few times even though I have had it awhile
Ist dies eine gute Frage?
Just open the Iron and adjust the thermo control and see it's heating or not .
If the Iron got heat it's ok or if not heat check the elements in the bottom then you can sure the fault.
War diese Antwort hilfreich?
Normally Heating devices are protected with what we called “Thermal Fuse” which are connected
in Series to the Main Line, If you can locate it it looks like a small fuse, crimped in a wire sometimes and comes in a different color like yellow, white or black.
sometimes it is covered by a shrinkable tube if you know it.
If you can use a Multimeter you can test the Leads of the Heating Element from end to end
there should be a low resistance reading from your meter should appear, if it not reads at all then your heating
filament is open. Its a sealed type.
please think always Safety do not work on it with Power connected , be sure Unplug the Power and
ask for a qualified serviceman if your not sure on doing it.
Have a nice day.
you can open the lid and check if power cable is disconnected from the element or maybe the element has blown up note that is irreplaceble
Letzte 24 Stunden: 13
Letzte 7 Tage: 92
Letzte 30 Tage: 412
Insgesamt: 23,454
1 Kommentar
My turbo Steam pro only used 30 mins a week and is very good except yesterday power on but no heat on the plate and water coming out, Guarantee is just out ,i am quite disappointed as my mums in the 70s lasted 15 years
I guess they purposely dont make them to last theses days.
von robert.reading1
