Zum Hauptinhalt wechseln
Simple to use 35 mm manual focus SLR camera. Model number X-370.
27 Fragen Alle anzeigen
Why am I seeing black after I take a picture?
When I go to take a picture I hear the shutter sound but all I see is black. I open up the film door and check there is a thin black sheet right behind the film that is not closing all the way. I have put new batteries in.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Your shutter is stuck. This has the side effect that the mirror will not return to its normal position, which blacks out the viewfinder.
Problems like these are not unusual in older cameras, and should be looked at by someone who's familiar with these old mechanical beasts. Avoid messing with the camera as you might make things worse - shutters are very delicate mechanisms. Keep in mind that spare parts are no longer readily available for these cameras.
EDIT:
Some research tells me that stuck shutters are a common problem with this particular camera.
There appear to be different causes for this problem. Sometimes, it appears to be a matter of "lack of exercise". One suggested solution is a gentle whack against the palm of the hand :) , another is the use of a fingernail to gently persuade the shutter to close completely - but be careful! In other cases, the problem seems to be caused by the camera's electrics, specifically, corrosion due to old leaking batteries. Check the inside of the battery compartment for corrosion, if you find any (greenish crud) have the camera cleaned and inspected - the corrosion may have propagated outside the battery compartment.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Marissa martinez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 17
Letzte 30 Tage: 95
Insgesamt: 4,791
