Extremely short battery life
Battery is not lasting more that 5-6 pictures.
Ist dies eine gute Frage?
Two possible fixes.
(1) reset camera
remove batteries
hold down power button for 1 minute
replace batteries
(2) increase battery contact pressure
remove batteries
using needle-nose pliers, bend battery contacts (in battery case cover) to better contact batteries
replace batteries
War diese Antwort hilfreich?
By default, as soon as you turn the camera on, it enables flash--even when not needed. Form this habit: As soon as you turn the camera on, every time, press the "up" arrow on the four-way pad to turn the flash off.
Not only will the batteries last much longer, but the camera will be ready to take the next picture much more quickly.
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 18
Insgesamt: 1,382
Do not use Alkaline AAs in a camera. You need rechargeable NiMH (Energizer seem the best). Or use Lithium AA one-time batteries (expensive!).
Rechargeable AA NiMH are best. But this is not a new camera, the A720. If you are using rechargeable batteries and this problem is new, it may be time for new camera.
von Brian Reeder
