Zum Hauptinhalt wechseln
Reparaturanleitungen für Leapster L-Max Konsolen
6 Fragen Alle anzeigen
How do I get the battery to charge?
I cannot get the battery to recharge. The green light flashes while charging for more than 8 hrs. Battery still not charged. I have cleaned the terminals as recommended by the company, but no luck.
I am willing to buy a new battery if I could just find one.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
Mine has batteries in it but isn't charger not even turning on what do I do is there anyway to reset it?
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
i searched ebay a little bit and found a battery cover/holder.
i don't know whats normally in the leapster l-max - but this holder looks like a 4 x aa battery holder: CLICK
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
Hi.
1. you can buy a wall charger (charge the battery connected to the wall socket) and connect to the ipod.
2. electro Shocks to your battery. You can use a power supply of 5V (for example an AC adapter with this power) and connect with a terminals to the pads of the battery this only has to be for a seconds, otherwise the battery will be burn.
after this process you can chek your battery with a multimeter
Bewertung 0
You plug in the charger to the wall, and then put it into your leapster device.
Bewertung 0
Antwort hinzufügen
Ruth wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 5,688
