Why does engine rev up and down when I step on brake?
My engine isn't missing at idle or acceleration. When I step on the brake it revs up and down as if it is going to stop, but it doesn't. I let off the brake it revs/runs fine...
Ist dies eine gute Frage?
24 Kommentare
anyone with an answer?
von Joe Henry
I have had this problem also.
von stoco
I have the same problem it's a leak in the break booster so when u hit the breaks it's letting extra air into the engine and therefore revving check for a suction,vacuum sound right behind the break pedal when braking it shouldn't be there. If this all matches replace your break booster
von Josh Wheeler
I have the same problem but I was also wondering if when it revs it wastes more gas, so I could replace asap. (It’s been using more gas than usual)
von Pablosoria
I am a mechanic and the most common problem to agree with the above comment it is a brake booster
von Christopher Tha King Hogan
19 weitere Kommentare anzeigen
