Zum Hauptinhalt wechseln
Hier findest du Reparaturanleitungen für Nähmaschinen.
94 Fragen Alle anzeigen
Bernina 830 service manual
Zigzag not working. Need a service manual. If anyone has one. PDF form would be great.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
4 Kommentare
I'm having trouble with the bobbin tension. Any suggestions?
von
Hi @nannamarg ,
This link may be of some help. See 2nd post down.
https://thequiltshow.com/forum/bernina-c...
von
I have just bought a nearly new but quite old Bernina Record sewing machine, but the clutch release wheel that you release to load the bobbin will not release, will it be ok to use a pair of grips to release it, or is the some other way to release it?
von
I filled a bobbin with thread and now the knurled screw on the hand wheel will not re tighten. Can someone help with this?
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Hey Cheryl, I found a link to the manual of your specific model here and the user manual here. The threadguide/lubricating unit pdf can be found here. You can check out the firmware details here.
-Let me know how it goes.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
iApple your first link and your second link are identical. Neither one of those is for the service manual
von
Thanks for notifying me oldturkey03, the link has been replaced with the service manual.
von
iApple you are funny. The first link is now the user manual, not a service manual. Big differences :-)
von
Hilfreichste Antwort
Cheryl, this video may help. On the bottom of this page is now a pretty good service manual about the adjustment of your sewing machine.
Bewertung 1
Hi Cheryl,
I see it has been almost 7 yrs. since you posted this inquiry, but I have an answer for you. I joined a group called .... BTS@ groups.io ... and found all of the service manuals and user manuals as a free pdf. download. The BTS stands for Bernina Thirtysomething. I tried to send it as a link but it did not work. I sure hope this helps.
Happy sewing!
Bewertung 0
Antwort hinzufügen
Cheryl wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 21
Letzte 30 Tage: 72
Insgesamt: 17,868
