Why is my laptop not charging?
I charged my laptop for more than 12 hours it was still not charged.
Ist dies eine gute Frage?
Sometimes the cord may be plugged into the computer, but it may not be properly plugged into the AC adapter properly. Make sure that the cord connecting the computer to the AC adapter is fully plugged in.
If the cord is connected to an electrical outlet extender, make sure it is on and fully connected to an outlet. It could be off and not transmitting the charge. If the cord is directly connected to an outlet, then firmly push the cord into the wall and check for a charge. If it is still not working, try a different outlet. You could have a short and may simply need to plug it elsewhere.
If the battery still does not charge you may have a malfunctioning battery which needs to be replaced. Check out this simple guide for battery replacement
Hope this helps!
War diese Antwort hilfreich?
Try this. Try unplugging the laptop, remove the battery. Plug just the power cord back in and see if the laptop will boot up. If so then we know the charger is working. Then try unplugging the power cord again, hold the power button in for about 10 seconds, this discharges the system, then plug the battery and power cord back in. If the battery still doesn't charge after this, then you need to replace your battery.
i have a new battery and battery charger and cable but it still doesnt charge up
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 1,151
got new battery and new leads and battery charger and still not charging
von Thomas Nutt
