Zum Hauptinhalt wechseln
Das erste Modell des iPhone, Modell A1203 mit 4, 8 oder 16 GB Kapazität und einer Aluminiumrückseite. Die Reparatur erfordert erhebliches Hebeln und möglicherweise auch Löten. Diese Seite soll Nutzer:innen bei der Fehlersuche und -behebung helfen und sie bei der Suche nach Hilfe für das iPhone 2G unterstützen.
224 Fragen Alle anzeigen
One of the antenna cables cutted and solded. No WiFi connectivity.
Hello.
Few days ago, the sim tray of mi old iPhone stuck inside, so I had to disassemble it.
I had a lot of problems to do it, and, in the proccess I cut one of the antenna cables, the one that is connected in the middle of the antenna ribbon sheet.
Edited: Read the actual situation below the first image.
The cable is cutted very closed to the metal cable support in the side of the phone (see the arrow in the photo), and I'm afraid that if the cable make contact with the support, the comunications board (or something else) could be damaged.
What do you think there is the best solution for this problem? maybe cut the cable in the other side of the metal support, and replace this fragment with a new cable?
Thank you very much for the help!
Edited:
I've read that the two wired are "the same", they are connected to each other and connect the comunications board with the antenna ribbon and the rear case.
I've solder the cutted cable and I've check with a tester the connectivity between the comunications board (1 and 2), the antenna ribbon (the two connectors) (3 and 4) and the rear case (5), all ok. The points are marked in the image.
See the image in full size
The problem is that I don't have WiFi connectivity. The GSM coverage is fine, but none the Wifi.
I have the phone disassemble, and I have connected the parts with a wire.
Any suggestions about the Wifi coverage?
Thanks!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
2 Kommentare
Please, can anybody tell me anything about my problem? :(
von
+ for a well stated question and illustrations.
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
agree, these are made without using soldering. cannot remember correct phrazeing, basically, solder in this case works as shielding. means, no signal gets through. you need to get a new set of antennas. these cost about 3USD, ebay...
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
Thank you very much for your answers, I'll buy a replacement cable set.
But... I think that the antenna cable is solded to the metalic support under the battery, am I right?
von
You may try just cutting off the ends of the broken cable and running the new cable along side the remains of the old one. You shouldn't need to solder the new cable along the middle. Perhaps just use some thin tape to hold it in place.
von
Last weekend I received the new cable and replaced the broken one.
WiFi now works perfect.
Thank you for the answers!
von
Hilfreichste Antwort
These are coaxial cables. They have an inner conductor that carries the signal plus an outer ground shield. Your best bet is to completely replace the broken cable.
Bewertung 4
1 Kommentar:
Any tips on how you did the replacement finally?
Did you remove the broken wire or not?
Bewertung 0
Antwort hinzufügen
jorgeoa wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 3,270
