Zum Hauptinhalt wechseln
Die vierte Generation des Surface Pro Tablets, erschienen am 26. Oktober 2015
210 Fragen Alle anzeigen
Is there anywere I can get a glass screen replacment
I have just dropped my surface pro 4 today ad its go a minor/bad crack in the screen, there is nothing else wrong with the machine so the LCD display doesn't need replacing. I've googled it but no suitable places have come up and not much information is being given. if anyone has any suitable places then I would love to give them a go.
I live in Hertfordshire so anywhere around there would be great
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 5
7 Kommentare
Frankie, I see you did not get any answer to your question. I have the same problem and I wonder if you have found a way to replace the screen. I would really appreciate your letting me know. Thanks in advance. Here is my email: jadecala@gmail.com
von
I just had the same thing happen to me. I am repairing it via the MS website for $619!!
von
same problem here.. try to googling for an answer & haven't found it yet
von
just found out that UAG have a robust cases for our pro4 with a sensible price.. little bit too late now :P
von
Hi my Sp4 i5 got damaged in transit to microsoft so i no how it feels found a site in america they do the screen but awaitinf stock heres the site address.http://www.powerbookmedic.com/xcart1/hom...
mike
von
2 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Is this what you are looking for?
http://www.techarmor.com/tech-armor-surf...
or this?
http://www.repairpartsplus.com/Replaceme...
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
no, niether of these work. one is a protector and the other is for a gen. 2.
von
I broke my surface after only a week of use, luckily I got the ifixit repair kit for Christmas!
Got my replacement off of https://www.walmart.com/ip/Microsoft-Sur... . With one day shipping (From CA to MA), it came out to ~$196.
Would recommend picking up some adhesive, because it doesn't come with it. I was in a rush so I went and picked up "Glue Dots", the "Mini Dot" variant. These worked quite well as they were very thin (~ 5mm). Was able to put them all around the inside of my surface, packed extremely tight. These in addition to a case (I have the Urban Armor Gear case) my screen holds up just fine as the edges of the case grasp the edges of the screen.
Extra info not provided about replacing screens, these screens generally do NOT come with the N-Trig board attached. (https://d3nevzfk7ii3be.cloudfront.net/ig...) Ntrig board picture . You can just remove it in a similar manner to the screen and adhesive it!
Bewertung 1
Antwort hinzufügen
frankie wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 5,333
