Zum Hauptinhalt wechseln
A tablet released by Hisense in 2014, identified by model number E2281.
36 Fragen Alle anzeigen
How do I replace the broken digitizer on my Hisesnse Sero 8?
(I'm a first-timer here).
Hello everyone, I dropped my Sero 8 tablet from desk height (cracking the digitizer in the process). When I turn it on, I can see my lock screen clearly (therefore the LCD must be fine), but the digitizer doesn't pick up input anywhere on the screen.
I think I know how to remove the broken digitizer, but how do I put on a new one?
And could someone provide a summary of removing the digitizer for the Sero 8 just so I can be sure I know how to do it?
What tools do I need? What tools would be useful but not essential? I know I need a blow dryer, and dinky little screwdrivers (what kind/size though?), some things to pry the screen off (and some things to put between the digitizer and the LCD prevent the adhesive from re-adhering)...
Anyone have recommendations for what I buy?
Thanks,
-Charlie
Ist dies eine gute Frage?
Bewertung 2
5 Kommentare
Someone please help me! I don't know what to do!
von
Hi,
I can't find any info about a Sero 8 digitizer replacement procedure. Here is a link which shows how to do a Sero 7 Pro digitizer replacement. It may be of some help, no guarantees that the Sero 8 will be the same. The disclaimer states that it is NOT an easy repair. Your decision.
https://www.youtube.com/watch?v=JtMyKmvD...
von
anyone else got some info?
von
Alright, I'm buying another tablet.
von
Well, I’ll be planning on repairing this same device in the future and show details in years.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
It would be great if you could contribute a screen replacement to the existing guides for this model. The current guides serve as a good reference point and the several youtuve videos for the Sero 7 can supplement any areas you may be concerned about.
Hisense Sero 7 Pro glass only screen repair as recommended by @jayeff
Hisense E270BSA - Digiter / Front Glass Replacement - Instructional Video
Hisense Sero 7 Pro Tablet Part 2 Taken Apart
As far as the tools you would need, those shown in the first video were:
Set of Picks
[verlinktes Produkt fehlt oder ist deaktiviert: IF145-000]
Spudgers
Tweezers - Pro / ESD / Blunt
Double-sided adhesive tape
Philips and flat head screw drivers
The links for the tools are those on iFixit for easy reference, but you can source these locally as well.
Since your current digitizer is broken, I recommend that you use packaging tape over the existing cracked digitizer to minimize small parts from breaking off. This may make it possible to remove it as one piece.
Spudger Bild
Produkt
Spudger
$3.99
Tweezers Bild
Produkt
iFixit Opening Picks (Set of 6) Bild
Produkt
War diese Antwort hilfreich?
Bewertung 2
Look on google it normally gives a dismantle process of most things
Bewertung 0
Antwort hinzufügen
Charlie wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 1,135
