john punkbuster, you could try a hard reset. "Hard reset
This will delete everything on your phone memory. Backup your data if you can. Make sure your phone battery is fully charged before performing hard reset
1. While the phone is off, press & hold below 3 keys simultaneously,
For SYMBIAN^3 phones (Nokia N8, C7, E7, C6-01, X7, E6): Volume Down Key + Camera Key + Menu Key
2. Ensuring that above keys are being pressed, Press & hold Power button until you see “Formatting” on your screen
3. Release all keys & wait for formatting to be completed
4. Once completed, Phone is like just out of the box
5. Most importantly, your security code is now reset to the
default 12345 - from here
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
5
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
12 Kommentare
gabrielkige@fikas.no
von Gabriel Kige Machotta
confused with the way I should answer your question
nokia n8 security code remove
von aryankhan
plaese help me
von aryankhan
I have my Nokia N8 working now after I had lost its charger. After trying to charge it by using my samsung S5, it worked but can not use it now because I have completely forgotten the code. Can you help me to recover my code.
7 weitere Kommentare anzeigen
