Zum Hauptinhalt wechseln
Reparaturanleitungen für Fahrzeuge der Marke Mitsubishi
113 Fragen Alle anzeigen
How to wire a push button horn? 2002 Lancer
My horn is gone in the steering wheel so while I save up to get it fixed I need a horn in the meantime.
So i have a button and two wires positive and negative.
Someone told me positive from the switch to the horn and negative from switch to batery, but it didn't work. Cos apparently the horn is always grounded.
There is power running to the horn.
Any help is greatly appriciated I have been trying for two months.
Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
3 Kommentare
Oh thanks ppl I'm going to try these except how do I test to see if it is broken?
Thanks
von
Connect a multimeter to the horn relay. When you push the horn button you should see that the relay gets excited and closes the contacts to the horn. Do you know where the relay is and do you have a meter?
von
No idea wat a multimeter is so probs so r have one.
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
you may want to test the horn to see if its ok you may not have a bad switch you may have a bad horn
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
By the way the horn is grounded and only needs power. to your switch run a positive and from there run a wire to your horn
von
Oh that sounds easy I'm gona try this. If this wrks ur a genious
von
Hilfreichste Antwort
You need to wire in a relay. The switch will not carry the current needed. Run positive from the switch to terminal 85 on the relay. Ground the switch to the body near the switch. Run a wire from terminal 86 to ground (negative). Run battery power into terminal 87 on the relay and run from terminal 30 to the horn.
Bewertung 2
Hi,
If the horn button on the steering wheel is not literally broken have you checked that the horn fuse and horn relay are both OK.
This shows the location of the horn relay.
Bewertung 2
2 Kommentare:
I may be considered over the hill but I can still read small print, but this is ridiculous. Make it LARGER so that we can read it without a Magnifying
glass. Please.
von
@Peter Rushbrook
If you hover the cursor over the image there is a magnifying glass symbol. Click on that and the image enlarges. Click on the enlarged image and it enlarges even further.
Moderator
von
Antwort hinzufügen
Sarah wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 14,641
